06-12-2016, 02:45 PM | #1 |
Drives: 2011 Camaro 2SS/RS L99 Join Date: Aug 2013
HELP please, O2 sensors not reading, got a CEL.
So these are the codes I currently have:
P0030: H02S Heater Control Circuit Bank 1 Sensor 1 P0050: H02S Heater Control Circuit Bank 2 Sensor 1 P0135: H02S Heater Performance Bank 1 Sensor 1 P0155:H02S Heater Performance Bank 2 Sensor 1 P0443 Evaporative emission Purge Selenoid Control Circuit My O2 fuse keeps blowing, I've looked at all the O2 wires under my hood and by my cats and could not find one that was melted or burned causing a short. Can not figure out why both front O2 arent working, any ideas please???
Stainless Power Headers, High Flow Cats, CAI intake, SLP Loudmouth 1 exhaust, Dyno tune from Alternative Performance |
06-12-2016, 03:11 PM | #2 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
I had my driver's side precat O2 sensor fail. It threw a TON of codes--actually codes for ALL the sensors (even tho I don't have rear sensors, and have the MIL disabled in the tune) and a powertrain code, too. (Can't remember exact codes, sorry)
The only way I could tell which one I needed to replace was to view the raw data in Torque. B1S1 was very slow and erratic response, while B2S1 was reading predictably. Replaced the failed one, reset the light, and no more problems. As far as your fuse blowing, sounds like a wiring problem, but it could also be a fault inside one of your sensors...albeit not very likely. More likely problem is some kind of rodent snacking on your wires. Good luck either way.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
06-12-2016, 03:18 PM | #3 |
If you don't have a multimeter to test for a short.....
Unplug all of them and see if it blows a fuse... If not plug one back in at a time to see which one blows the fuse. If it blows without them plugged in... must be wiring... My guess is that one of the heated sensors is shorted out internally.
2014 L99 2SS. 595HP/571ft-lbs
Mods: LSA Conversion 2.5" Upper Pulley, 65# injectors, GPI SS1 Cam, SP Long Tubes, ADM Race Scoop & CAI, NPP exhaust (DIY control), BMR 1" lowering springs, ZL1 Rear Differential / Axles, CF Side Strip / Hood Spear, Tint - Windows / Tails / Sidemarkers, Splash Guards, ADM Boost Gauge, ABL Dashkit, '68 Script Badges, ACS T4 Splitter, ZL1 Rockers from Gary's, Z28 Spoiler, Carbon Fiber Hood Vent, Summer - MRR FS01 Satin Black (10" Front 11" Rear) Winter, pictured-Drag DR 64's Satin Black (9" Front-10" Rear.) |
06-12-2016, 04:22 PM | #4 | |
Stainless Power Headers, High Flow Cats, CAI intake, SLP Loudmouth 1 exhaust, Dyno tune from Alternative Performance Last edited by Detroit Muscle; 06-12-2016 at 05:02 PM. |
06-12-2016, 06:12 PM | #5 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
There you go, it's in the wiring to the 02s
06-23-2020, 11:21 AM | #6 | |
Drives: 2014 Camaro ss Join Date: Jun 2020
