07-22-2018, 05:14 PM | #1 |
Drives: 2010 camaro Join Date: Dec 2017
Any help for 2nd gear crunch on manual transmissions
My 2nd gear in my ss won’t go in without a crunch. This happens at low speeds. If i row thru 2nd like I’m racing for the quarter mile, then it dosent do it. Any help would be greatly appreciated. Car has 10000 miles and 2dealers already said they felt noting wrong with it.
07-22-2018, 05:16 PM | #2 |
Not exactly a grind but a crunch. I just thought this pic would be funny
07-22-2018, 05:47 PM | #3 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Mine feels the same way. I think it has something to do with the sync rings. My old M21 felt the same way when I rebuilt it and put in new rings and gears. Just feels real tight without a lot of slop.
07-22-2018, 06:39 PM | #4 |
Drives: 2016 Camaro SS Join Date: Jul 2016
1st and 2nd gear use a triple cone synchro - I can hear/feel it on mine as well. Especially when it starts to get cooler out and the fluid is a bit thicker at startup.
I will say that active rev match calms a lot down at slower speeds on that trans. |
07-22-2018, 07:43 PM | #5 |
Drives: 2016 2SS Camaro fully loaded. Join Date: Nov 2016
I've had mine grind once or twice before. Wasn't the gear because clutch was all the way in, so I assume the synchro. I felt like I was all the way down into gear but it wasn't. Definitely requires a firm pull into place sometimes.
07-22-2018, 11:53 PM | #6 |
put better fluid in it Amsoil ATF or torque drive. Has fixed it if there is no damage.
07-23-2018, 01:29 PM | #7 |
Banned
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
Sounds like worn synchronizers...let GM fix it under warranty.
07-23-2018, 02:40 PM | #8 |
Drives: 2016 camaro 2ss Join Date: Feb 2018
It’s not the stupid skip shift feature? Thing irritates the shit out of me. Have a skip shift eliminator sitting in the glove box. Need to install that.
07-23-2018, 04:00 PM | #9 |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
GM 6mt has had this issue for many years. My 2004 Corvette 6 MT did it and the Corvette forum was filled with people with this issue.
07-23-2018, 07:51 PM | #10 |
thanks for the responses people but it is not the skip shift. i put the eliminator in it 1000miles ago thinking that would fix the problem and it didn't. It's hard to enjoy this car when that frankly is the only problem with it. I will try to put that amsoil fluid in it when the car gets on a lift and report back. I just don't want to break the gear or something like that since the dealership said its normal. I have to get on it hard as if I'm racing or something of that nature for it to go in 2nd with ease.
07-23-2018, 11:13 PM | #11 | ||
Drives: X-15 Velocipede Join Date: Mar 2008
Still grinds? Put GM fluid back in and get defective synchronizer replaced. Or skip to: get defective synchronizer replaced 5
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer STANDARD DISCLAIMER camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to, any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free. |
07-24-2018, 07:00 AM | #12 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
Same with mine. Definitely NOT a grind. But worse when cold. I've already had the dealer change the fluid. Next change I'll use a different fluid. I'm not concerned. Tranny feels solid.
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
07-24-2018, 10:08 AM | #13 |
Drives: 2016 2SS, Red Hot, NPP, Nav, M6 Join Date: Jul 2016
Mine does this sometimes when the weather is cold. Hasn't really concerned me and I love this transmission.
How tough is it too change the transmission oil yourself in this car? I would like to change out the fluid sometime and the differential also, just don't want to pay the dealership to do it. Just a cheap old man I guess... |
07-24-2018, 10:32 AM | #14 |
Drives: Tesla M3 LR-AWD [Former 1SS owner] Join Date: Jan 2018
At very low speeds, if the shifter isn't slotted into 2nd correctly (requires a somewhat firm action), it can slip out and grind. It's a quirk of the tranny and more than likely a 2nd gear synchro design issue, but nothing to be really concerned about, just mindful. With the tall gears, this tranny is definitely smoother when shifted at higher RPMs. Just my 2 cents.
