11-17-2018, 08:07 AM | #1 |
Drives: 2011 Camaro SS/RS Join Date: Feb 2011
TvS2300 Maggie jack shaft catch cans
What are type of catch cans are yall using. Running about 12lbs boost and probably would need the dual cable catch can, but I don't see that many instructions for an install with Maggie blowers so it's making it real hard to choose from. My top picks are
1. E2x dual catch Can 2. Tracy lewis catch 3. Mighty mouse catch Any instructions on how yall got y'alls installed or have pics would be great. Thanks
SLP TVS 2300- 1 7/8 LG Headers- RDS NX Plate- 75 Shot- No Cats- SLP Loudmouth 2- NW102- 3.8 Pulley- OD Cog drive-12lbs boost-FIC 80# injectors-ZL1 Fuel Pump- RotoFab CAI- Apex CAI Scoop- Pat G Tune- Weld RTS drag pack- BMR Trailing Arms- BMR 1'' Drop Springs-BMR Lower Control Arms- BMR Toe Rods- BMR Rear Cradle Bushings- BMR Upper Control Arm Bushings- BMR Extreme Anti- Rollbar- Hotchkis Subframe Brace- Prosport Evo Boost & F/A Ratio
11-24-2018, 09:03 AM | #2 | |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
11-24-2018, 09:35 AM | #3 |
I was told to go dual for a force induction. Any reason why to go single? Thanks for replying. Just curious.
11-24-2018, 05:59 PM | #4 |
You don’t want to start messing with crankcase pressure and adding in-line valves ETC. Stick with how the engineers at GM designed the system to work however improve upon it with installing a single exit catch can to trap the oil from entering the combustion chamber. That’s what I was told when I considered switching to dual exit system by the engineer who developed for GM and the founder of the RXT cans..
11-24-2018, 06:08 PM | #5 |
“ We generally don't run the dual port catch-cans on Naturally Aspirated or PD supercharger applications; we run the single port without the check valve. The PD (Positive Displacement) superchargers create pressure behind the throttle body thus allowing the factory PCV system to function as it normally would stock. The catch-can is simply there to catch the crap that is produced during the combustion cycle from going into the supercharger or manifold in an NA application. “
The dual exit is better suited for turbo or centri applications. Good luck brotha! |
11-24-2018, 06:15 PM | #6 | |
12-24-2018, 10:42 PM | #7 |
Drives: 2015 Supercharged Camaro 1LE Join Date: Mar 2018
I have a magnuson supercharger also and want to add a catch can. Does anyone have a part number please ?
Magnuson Supercharged 2015 1LE RS/2SS. Texas Speed Stage 3 Blower Cam. DSX Aux Pump. e85 Flex Fuel Kit. BMR Suspension. On Instagram @wakeyourneighbors @Blown1LE
09-23-2019, 08:21 AM | #8 |
Thread Tools | |
