05-01-2020, 11:50 PM | #1 |
@_cherrypoppins
Drives: 15 Camaro 2SS/RS Join Date: Mar 2019
Front suspension upgrades?
I see a lot of upgrade parts for the rear suspension, but what is better than stock for the front.
Right now my front end has only been upgraded to 27mm pedders sway bar. What else is everyone doing in the front? |
05-02-2020, 09:25 AM | #2 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Not much needed really needed. Z28 arms maybe to sharpen steering. Coilovers all around.
05-02-2020, 01:46 PM | #3 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
Strut tower brace if you dont already have one. They say it doesn't really do anything, but
felt a small difference when I bought mine. |
05-02-2020, 01:48 PM | #4 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
There are a few bushings you can replace.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
05-02-2020, 01:49 PM | #5 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Coil overs. Lowering springs. 1le handling package. Better sway bar links. To name a few things.
05-02-2020, 08:07 PM | #6 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
The Z front lower control arm does have a stiffer rubber bushing. I upgraded it from my OE 1LE LCA. And as VR Baron mentioned, it sharpened my steering. The Z radius rod is the same as the 1LE except that it has an upgraded insert within the bushing. I try to stay away from poly bushings, they will deform over time. Not good.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
05-02-2020, 09:15 PM | #7 |
USA-1
Sway bar bushing upgrade/radius arm insert...
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
05-02-2020, 09:37 PM | #8 |
Drives: 2010 2SS/RS Join Date: Dec 2009
I use a 1LE front bar with a 32mm rear bar, JPSS radius arm inserts, 1LE struts, and ZL1 front brake set up.
Orange Krush II
05-02-2020, 09:44 PM | #9 | |
05-03-2020, 12:18 AM | #10 |
Drives: 2015 2SS A6 Commemorative Edition Join Date: Nov 2019
I had to make adjustments to front and rear to get the results I was looking for. Maybe more info than requested, but I did the following....
20x10 +35 wheels front and rear with a square 275 setup - virtually eliminated the inherent understeer. 1LE Strut tower brace - seemed to stiffen things up BMR 29mm front and 32mm rear adjustable sways (SB039) - greatly improved body roll in hard and high speed corners, provided the ability to adjust bias front to rear. BMR 1” lowering springs (SP019) - lower center of gravity, progressive rate, made the car more responsive Tight spec aggressive alignment, -0.8* rear (Minimum negative camber with stock camber bolts when lowered), -1.5* front (to maintain front to rear balance). The car handles excellent in high speed curves and tight corners with this setup, but the aggressive camber isn’t ideal for straight line digs. Trying to find an alignment compromise between handling, tire wear, and traction during acceleration - I’m now waiting on +1* eccentric camber bolts to lessen my camber to -.5* rear and -1.2* front. Pretty long winded, but I have access to alignment racks and do the work myself, so I figure if I share my trial and error, maybe I can save someone some money and a few trips to the alignment shop. |
05-03-2020, 09:26 AM | #11 | |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
More to come. |
05-03-2020, 09:33 AM | #12 | |
I did the Z LCA this winter along with the stiffer Z front wheel bearings in an effort to better control camber when loaded. I have not been on track yet to see any changes, but I felt the change with sharper steering. I'm glad I did those for the feel alone.
05-03-2020, 09:58 AM | #13 | |
05-03-2020, 10:12 AM | #14 | |
