Old 03-16-2021, 11:02 PM   #1
_Onyx_Wolf_
Instagram^
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
Agp twins with a stage 4 na cam?
Would the Tsp f-35 stage 4 n/a be okay with some agp twins? Lol I know it wouldn’t be the best cam but does the cam even really matter In this setup? I mean I heard a lot about the night fury stage 3 na cam making good numbers with the agp twins.
_Onyx_Wolf_ is offline   Reply With Quote
Old 03-17-2021, 03:56 AM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
You'll make plenty of power and I would not change the cam.
Old 03-17-2021, 07:00 AM   #3
RupertPupkin
Drives: 2014 Camaro SS 1Le
I stumbled on this awhile back. Good video to watch https://youtu.be/SzXjw3Png3E
2014 SS 1LE Money Pit
802Whp/662Trq
RupertPupkin is offline   Reply With Quote
Old 03-17-2021, 10:32 AM   #4
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
eventually you'll hit a power level where the cam overlap does not allow you to build additional boost. Really depends on your total power goals
2011 Camaro 1SS
Whipple Supercharged street monster
Aries240SS is offline   Reply With Quote
Old 03-17-2021, 11:18 AM   #5
_Onyx_Wolf_
Instagram^
Good video!
Old 03-17-2021, 11:20 AM   #6
_Onyx_Wolf_
Instagram^
Looking at 1300whp with a dart iron 427 short block
Old 03-17-2021, 11:22 AM   #7
_Onyx_Wolf_
Instagram^
Thanks for the input it’s from a n/a build I had that went south and windowed the block lol cam looks fine though
Old 03-17-2021, 11:53 AM   #8
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Great video and thank you for posting that. I've been a subscriber of his for a good bit now, but have never seen that one.
15 Camaro SS- GPI max top end, ESS Vortech V3 10psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft and much much more
gunchamp is offline   Reply With Quote
Old 03-17-2021, 12:36 PM   #9
eLeSthree
Drives: 2011 Camaro SS 6sp
Hell with a Dart 427 that isn't assembled yet, I'd get a turbo cam. Video doesn't consider drive-ability.
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Tuning Triples and FF, FIC1300, Mcleod RXT 1200HD, 1030whp 925wtq.
eLeSthree is online now   Reply With Quote
Old 03-17-2021, 12:56 PM   #10
_Onyx_Wolf_
Instagram^
Haha I know I’m just tryna save where I can and the f-35 cam I have had prolly 2k miles on it if that. Driveablity wasn’t that bad for a stage 4 would it be worse with turbos?
Old 03-17-2021, 01:29 PM   #11
RupertPupkin
I have Ticks stage 3 polluter cam (233/248 | .627”/.612” | LSA113+5), which the specs are very similar to the F-35 (235/248 .649"/615" 111 LSA, 109.5 ICL (Other LSAs Available)
Drivability is subjective. Different strokes for different folks.
802Whp/662Trq
Old 03-17-2021, 01:32 PM   #12
_Onyx_Wolf_
Instagram^
That can was bitchin too that was my last cam before a lifter went and trashed it
Old 03-17-2021, 02:22 PM   #13
RupertPupkin
If you like how your F-35 drive, it’ll be the same. You’ll just have more sound like psssshhhh and whissssttttleeee. Lol
802Whp/662Trq
Old 03-17-2021, 02:30 PM   #14
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX427 TT
Saving money building up an engine
Not going to cost much more having a custom grind to optimize with the rest of the motor to make the most power with the combination with lessor boost. If you're only shooting for 1300whp , that's the way I'd go (again).
In excess of 1,000WHP
LSX427 | AGP 65/65 TT | BTR Equalzer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | NGK BR7EF | RPM Lv 7 TR6060 | AGP's Fore Triple Fuel | Monster LT1-S Triple | 3.25 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
