08-21-2013, 09:54 PM | #1 |
Drives: 1970 Pontiac GTO Join Date: Jan 2012
FS: L99 stock parts
all 30k miles, need to add shipping on all these.
L99 Cam 40$ L99 lifters(4 normal, 4 shutoff) 20$ L99 Cam gear 15$ L99 Cam gear bolt 10$ L99 timing chain cover 10$ SOLD L99 timing chain 10$ L99 tensioner 10$ SOLD L99 lifter trays(all 4) for 15$ L99 valley cover 35$ Stock oil pump 40$ Stock headers and heat shields 50 each Last edited by Mikes2nd; 08-27-2013 at 02:19 PM. |
08-21-2013, 09:58 PM | #2 |
Drives: 2014 CTS-V- totalled/ 45TH ss- SOLD Join Date: May 2013
If I buy the lifters that are normal, can u use it for dod delete? Or should you change them regardless
2014 CTS-V... with some go-fast bits coming
08-21-2013, 10:07 PM | #3 |
hmm I think they can turn off dod with your programming? And I don't see why you couldn't toss in the other normal to remove the mechanical junk.
I saw some threads on this. |
08-21-2013, 10:09 PM | #4 |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
They are weak. If you plan to change lifters get the good stuff.
08-21-2013, 10:41 PM | #5 |
Drives: 2011 2SS Convert; Color RJT Join Date: Sep 2009
PM sent on Tensioner/timing cover.
