09-12-2018, 09:35 AM | #1 |
Drives: Stock 2013 camaro ss l99 Join Date: Feb 2018
Camaro idle problems
I'm trying to figure out what is wrong with my car. The car has a tsp cam shaft with a 3200 stall converter. Car searches for an idle when started. Also when I'm driving and come to a stop the car normally stalls out.. video shows the start up.
https://youtu.be/tY86sovW57I |
09-12-2018, 11:58 AM | #2 |
Started#gottalovethatblue
Looks like a tune issue if I had to guess. I can't imagine that's supposed to happen.
09-12-2018, 01:45 PM | #3 | |
Drives: 2012 1SS M6 IOM Join Date: Dec 2012
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018. |
09-12-2018, 07:51 PM | #4 |
Sounds tune related, but no CEL. May hit up DynoSteve. He is always willing to help ANYBODY.
On a side note though, that thing sounds like a freaking beast..... Hope someone chimes in and you get it sorted out though. |
09-12-2018, 09:06 PM | #5 |
It was tuned, right? I would assume so, with a cam and stall, but we know nothing.
Did it run great after the tune and then just start doing this or has it always done this since the cam install? More info man, more info! We have some very intelligent and experienced LS guys here, but you gotta feed them the particulars.
09-12-2018, 10:19 PM | #6 |
Car ran great for about 2 weeks after the tune.. then started throwing codes because tuner never deactivated cylinder deactivation. Then started having these problems when starting the car and coming to a complete stop.
09-13-2018, 07:11 AM | #7 |
old school chevy rodder
Check connections is the first thing to do, having been worked on recently it could be anything from a loose vacuum hose to the PCV system, to a loose ground to the fuel injection..... Make sure the MAF is on and sealed well and has a gasket or oring, the catch can has no loose hose, the etc etc is good, sounds like a stumbling due to something not being right. Good Luck.
09-13-2018, 08:00 PM | #8 |
Drives: 2010 2SS Join Date: May 2015
Working with dynosteve right now with same issue
Thread Tools | |
