07-10-2014, 03:02 PM | #1 |
Drives: 2017 Jaguar F Type R Tuned 498awhp Join Date: Apr 2013
Sway bar install on 2013 SS
For those of you that installed the sway bars in your garage...
Did you have a difficult time getting the front one out using jack stands? Did you have to raise the motor? Thank you for your feedback
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
2017 Jaguar F Type R ''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller |
07-10-2014, 03:09 PM | #2 |
Sold car...
Drives: 2010 Rally Yellow 2SS/RS #37115 Join Date: Oct 2009
Just a bit of a pita. Didn't raise motor but I did take off ps unit bolts. It's trickery but can be done. We actually slid it towards passenger side first than dropped the drivers side down between frame and out drivers side.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust. |
07-10-2014, 03:43 PM | #3 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
I raised the motor for the front bar. Only loosened a couple of bolts, didn't fully remove them, and raised everything an inch or so.
Removing the exhaust (just the axle-back) makes the rear bar 100x easier as well regardless of year.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
07-10-2014, 04:10 PM | #4 |
Drives: Race Car Join Date: Sep 2009
Exactly what we would suggest!
07-10-2014, 05:02 PM | #5 | |
Best regards, Tyler 888-308-6007 |
07-10-2014, 07:20 PM | #6 |
Thanks guys!
07-10-2014, 09:47 PM | #7 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
What the rest said
07-12-2014, 09:03 PM | #8 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
I didn't remove or unbolt anything, although that could make it easier. The front one is a pain to get out and a thicker one tough to get in but it can be done. I used jack stands and left the bushings/clamps in place.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
07-13-2014, 09:41 AM | #9 |
Drives: 2010 2ss red LS3 Join Date: Aug 2011
I did it in my driveway on jack stands 2 yrs.ago. A teenager helped. It takes some finagling, be patient. Remove from right side.
Pedders Pace Car Kit with ZL1 sway bar conversion & camber bolt kit.Lowered 1.5". 1LE tires & wheels. CAI air intake. Anvil CF rear spoiler.MGW shifter. 1 7/8" Kooks LT headers & HF cats.V-Max ported TB. Tuned.
