09-26-2016, 05:45 PM | #1 |
Drives: 2020 SHOCK SS 1LE Join Date: Sep 2016
Does your V6 idle smoothly?
I'm still getting use to my 2016 V6 Camaro. I just hit 500 miles on the car. I noticed it doesn't exactly have the smoothest idle. I can definitely feel it coming through the car while in park or waiting at a red light.
Is this a normal Characteristic for this engine? Tachometer needle reads fine (doesn't jump around or anything abnormal) and otherwise drives fine. My daily driver for about the last 15 years was my LS1 Camaro, which in my opinion has idled smoothly even to this day. |
09-26-2016, 05:59 PM | #2 | |
Drives: 2018 Camaro 1SS 6spd Join Date: May 2016
Mine does the same thing also... |
09-26-2016, 06:00 PM | #3 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
you might not be used to direct injection I think.
09-27-2016, 01:14 AM | #4 |
09-27-2016, 06:59 AM | #5 |
Drives: 2016 Camaro 1LT M6 Join Date: Aug 2008
It's a combination of things. First, the V6 has a pretty low idle once warmed up. You'll notice it idles around 1200 when you first start it and then it'll idle down to around 700. That's pretty low and helps introduce some rough character. Second, the DI doesn't help either. Third, if you have the AC on max it's very noticeable.
But, it seems like it's completely normal and it's crazy because of how smooth the engine is in every other way. |
09-27-2016, 09:45 AM | #6 |
Drives: 2016 camaro lt2 rs Join Date: Feb 2016
if you came from a 4th gen with an ls how did you not feel it? i have a 3rd gen and it rumbled. this car is so much smoother that. any car with 300+ hp is going to feel like this.. nothing to worry about.
09-27-2016, 10:31 AM | #7 |
Thanks for the replies, glad I'm not the only one who notices it. Still getting use to the car and this engine.
09-27-2016, 10:33 AM | #8 | |
Haha. I always felt that the ls1's had a smooth idle, provided they were well taken care and fairly stock. |
09-27-2016, 10:35 AM | #9 | |
09-27-2016, 01:08 PM | #10 |
Drives: 2016 V6 RS Manual Join Date: Feb 2016
Mine shakes, so does my manual shift knob
09-27-2016, 06:40 PM | #11 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
Mines decently smooth. Every now and then you get a blip, but that's nothing.
700 is kinda normal these days. My 07 charger was set at 650 I believe and that was a decade ago...Non direct injection though.
Don't sit around and watch everyone else live YOUR dreams...DO SUMPT'N
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
