02-19-2013, 10:14 PM | #1 |
Drives: 2011 SS/RS Join Date: Apr 2011
Draining fuel tank?
My car has a half of a tank of fuel in it an was wondering if there was an easy way to drain the bad fuel out WITHOUT removing the tank? I seen an old post where a member used up tuners to run fuel pump, but I don't have access to hp tuners...
02-19-2013, 10:19 PM | #2 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
Buy a siphoning pump from Home Depot, stick one hose in the tank and the other in a 5 gallon fuel can.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
02-19-2013, 11:03 PM | #3 |
Drives: Anything Blown Join Date: Aug 2010
You forgot the bottle of listerine for afterwards!
02-20-2013, 05:18 AM | #4 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
Can't siphon it, there is a check ball in the filler neck.
02-20-2013, 05:43 AM | #5 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
Yup.
Why is the fuel "bad"? Unless you accidentally put diesel fuel in it, top if off w/ fresh gas and stop worrying.
NY5thgen.com
02-20-2013, 11:06 AM | #6 | |
The fuel has been in the tank for a few months now due to repairs and bad weather. Before the car was parked I was getting some KR and tuner said has to be bad fuel and to take it easy until I burn it out and refuel. The weather is still nasty out and if there was an easy way of draining it I would much rather do that to save time and possibly determine if the KR was bad fuel or something else. |
02-20-2013, 11:17 AM | #7 |
Banned
Drives: 2011 CTS-V, 2010 SS Join Date: Feb 2013
Fill up the tank and put a fuel additive in and just keep foot off accelerator.
02-20-2013, 11:25 AM | #8 |
Drives: 2011 2ss/rs Join Date: Nov 2011
theres no easy way to do it. i jsut dropped the fuel tank yesterday on my ss. unless you unclip the fuel feed, and hood you tube onto that and siphon out that way, thats easiest, at the front right corner of the fuel tank theres a BLUE connector, thats the fuel feed.
02-20-2013, 11:49 AM | #9 |
Disconnect the feed line to the fuel rail, run a hose to a tank and hot wire the fuel pump relay on.
Nick
Corvette Z06 -1200ish rwhp |
02-20-2013, 01:11 PM | #10 |
I.AM.
Agree. Not worth the effort of draining.
NY5thgen.com
