Old 03-24-2013, 03:39 PM   #1
SSKyle
Drives: 2011 SS/RS
ADM FPCM
Can anyone post up a link for the fpcm for the ZL1 pump? I can't find it on their site.
Thanks
SSKyle is offline   Reply With Quote
Old 03-24-2013, 04:41 PM   #2
2012REDSS
Drives: 2012 Camaro SS
Pm or call Andy. Great product. It does the trick and the data log will prove it
2012REDSS is offline   Reply With Quote
Old 03-24-2013, 05:09 PM   #3
Adadda
Drives: 2012 Camaro SS. L99
http://admperformance.com/categories...29&category=69
Right on their site
Adadda is offline   Reply With Quote
Old 03-24-2013, 05:14 PM   #4
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Ya, he added it a few weeks ago.
Iam Broke is offline   Reply With Quote
Old 03-24-2013, 05:58 PM   #5
SSKyle
Drives: 2011 SS/RS
Thanks a lot.
How hard was it to get to the fpcm? I know you have to remove the back seat and the side panel, but other than that is it pretty a straight forward install?
Old 03-24-2013, 06:09 PM   #6
ToddB
Drives: 2011 2SS Convertible Supercharged
Easy as pie.
ToddB is offline   Reply With Quote
Old 03-24-2013, 06:49 PM   #7
2012REDSS
Yep removing the seat was the hardest part
Old 03-24-2013, 09:58 PM   #8
Scourage
Syntax Error
Scourage's Avatar
Drives: 2010 Camaro 2SS/RS
I did it without removing the seat, just pulled the rear pass side panel back far enough to swap it out, wasn't too tough.
Scourage is offline   Reply With Quote
Old 03-25-2013, 06:46 AM   #9
StreetSS
Drives: 2011 Camaro SS
Removing the rear seat is fairly easy as well, if you choose to go that route. It is not necessary to remove any bolts. Pull up on the front of the lower seat to unclip and unhook at the back by pushing down where the hooks are (located maybe a foot from either side). To remove the top part of the seat, pull it down as if you are trying to accesss the trunk and use the latches at either side to release the seat back from the tubular mount and pull up. There are DIYs on here with pics if needed.
StreetSS is offline   Reply With Quote
