12-26-2014, 10:42 AM | #1 |
Drives: 2013 Camaro SS 1LE Join Date: Oct 2014
single turbo pcv
building a single turbo with blow thru MAF. what can i do about the pcv system? if i use a breather cap it will allow unmetered air into the system. or will it not be that much of an air leak? i searched but im still lost on it.
12-26-2014, 03:09 PM | #2 |
Vent to atmosphere
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
12-26-2014, 03:13 PM | #3 |
so breather both valve covers? remove pcv?
12-26-2014, 04:37 PM | #4 |
Silver Ice
Block clean side and vent dirty side to atmosphere if I am not mistaken. But I am no pro in boost. I would definitely email one of the tuner kit companies and pretend that you are interested in buying their kit, then ask about how to vent.
12-26-2014, 07:50 PM | #5 |
Drives: 2011 SS/RS Join Date: Apr 2011
12-26-2014, 09:34 PM | #6 |
Vent both covers, ideally with larger lines, and if you want run a check valved PCV setup off valley cover to pull some air out idle/part throttle.
Nick
Corvette Z06 -1200ish rwhp |
