Old 01-09-2017, 04:48 PM   #1
SSKyle
Drives: 2011 SS/RS
Texas speed headers and x pipe
Those of you with the tsp headers and x pipe, did you have any problem with the 3" pipes being too close to the driveshaft coupler by the rear end or the rear end in general?
If anyone has a pic of this setup under the car it would be much appreciated
SSKyle is offline   Reply With Quote
Old 01-09-2017, 09:33 PM   #2
GTG91
GTG91's Avatar
Drives: 2008 duramax
please refer to my post in this same section, just posted my experiences with TSP
when it comes to car parts you have three options..fast, cheap, or reliable... but you can only pick two
GTG91 is offline   Reply With Quote
Old 01-09-2017, 09:39 PM   #3
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
His post can be found here!
Hopefully you don't run into the same issues he has! Good luck on your exhaust build!
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 01-11-2017, 06:14 AM   #4
Camarojamie
Banned
Drives: 2010 Camaro ss 6speed
No just installed them on mine great figment an best customer service I have found next to dyno Steve
Camarojamie is offline   Reply With Quote
Old 01-11-2017, 09:21 AM   #5
Twincat800
Drives: 14 2ss/rs
That sucks i was wanting their headers and x pipe
Twincat800 is offline   Reply With Quote
Old 01-14-2017, 07:32 PM   #6
SSKyle
Drives: 2011 SS/RS
Update
With some minor adjusting I got everything lined out. Although the passenger side mid pipe is still a little closer (5/8") than I'd like to the driveshaft coupler, I believe it should be fine. On the down side I can no longer use the cross brace that went across on the factory setup due to the 3" pipe and the headers are a bit lower than factory pipe.
Old 01-14-2017, 07:49 PM   #7
shnormo
Drives: 2010 1SS Camaro
I didn't have clearance concerns with the driveshaft coupler. I was slightly disappointed when the stock body cross brace didn't bolt up either. How many would be interested in a custom brace?
shnormo is offline   Reply With Quote
