Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 03-28-2019, 05:19 AM   #1
tredye
Drives: 2012 RS LT convertible
Wheel center with wheel opening
I would like to know if this is a adjustment or something bent
tredye is offline   Reply With Quote
Old 03-28-2019, 09:49 AM   #2
broshua
broshua's Avatar
Drives: 2015 Chevrolet Camaro 1SS
How does it compare with the passenger side? Could be something bent or maybe even caster. Did the driver side get impacted by anything?
broshua is offline   Reply With Quote
Old 03-28-2019, 10:40 AM   #3
tredye
No I have already had a Dent repaired by the dent Doctor paintless dent removal ,A guy backed into as I was driving past I was in a parking lot going about 15mph,and he gunned his Chrysler 300 backing up ,I have 1 inch spacers on my wheel to make them fill out the fender well better so the quarter didn't take all the impact the Rim and tire did
Old 03-28-2019, 10:54 AM   #4
broshua
broshua's Avatar
If the wheel/tire took a lot of the impact then I will assume something got bent or the caster is way out of spec. I would take it to an alignment shop and have them check it out. Did you happen to see if the passenger side wheel and gap look the same?
Old 03-28-2019, 11:40 AM   #5
mr_honez
Wifey Lover
mr_honez's Avatar
Drives: 2013 Crystal Red 2LT/RS
That looks waaaayy off. Just looked at the side of mine and it is even all around the tire. Something is bent IMHO.
mr_honez is offline   Reply With Quote
Old 03-28-2019, 02:51 PM   #6
tredye
Yep is even all the way around on the other side but I can't see anything bent. Its a inch of on the side of my picture up front of the wheel well
Old 03-28-2019, 03:14 PM   #7
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Switch the wheels and see how they look on different sides.
camguynj is offline   Reply With Quote
Old 03-28-2019, 03:30 PM   #8
tredye
Why switch the wheels?
Old 03-28-2019, 03:41 PM   #9
camguynj
camguynj's Avatar
Just to confirm it’s the hub that’s off alignment and not the wheel
Old 03-28-2019, 07:15 PM   #10
tredye
I took the wheel and the hub is moved back to the rear 1 inch
Old 03-28-2019, 07:17 PM   #11
tredye
Can The rear camber be adjusted on a 2012 ?
Old 03-29-2019, 10:29 AM   #12
tredye
Took it back to the statefarm adjuster put it on a lift top control arm bent!!! He getting my dealer to or get the parts hope to get it fix next week
Old 03-29-2019, 10:36 AM   #13
broshua
broshua's Avatar
Nice. At least they were able to track it down and get it fixed for you. Hopefully a quick turn around.
Old 04-03-2019, 02:22 PM   #14
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
yeah was gonna say looks like rear diff is all bent out of place , not the rim... lol
Hellfighter is offline   Reply With Quote
