Old 08-08-2018, 01:25 PM   #1
Matt8892(2)
Drives: Black camaro 2ss 45th
Installed 14-15 SS hood vent on my 2012 today
Got my template made and all the hardware I needed for the install over the course of two days. Taped everything up and I measured about 19 times. Then had my father check. Then had my cousin check measurements. After adjusting the template a million times I finally committed and traced out the line and got to cutting.
Matt8892(2) is offline   Reply With Quote
Old 08-08-2018, 01:28 PM   #2
Scotty D
Drives: 2014 1le 1SS CRMT
Looks good bro
Scotty D is offline   Reply With Quote
Old 08-08-2018, 01:29 PM   #3
orangecush
Drives: 2010 camaro 2ss
Great work.Looks awesome
orangecush is offline   Reply With Quote
Old 08-08-2018, 01:40 PM   #4
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Very nice job .. looks great
Old 08-08-2018, 01:46 PM   #5
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Very nice work. Looks really good....
I hope you don't mind I rotated some of the photos so they were easier to see... If you wanted them the way they were, let me know and I'll switch them back...
Old 08-08-2018, 01:54 PM   #6
Matt8892(2)
They’re perfect. Thank you. They all were straight when I uploaded. Then twisted when I submitted the thread
Old 08-08-2018, 02:06 PM   #7
Sinister10
Sinister10's Avatar
Drives: 2010 Camaro SS
Looks great!
2010 2SS/RS 6M, MGW flatstick, CAI cold air intake, SLP loudmouth 2 axleback, TSP 1 7/8 headers w/ hfc, pfadt 1" springs (not installed), SRP pedals, emblempros "6.2L" emblems on hood, ZL1 grill, M/T SC-5 wheels, nitto motivo 275f 315r. ZL1 addons wickerbill, smoked lenses, resonator delete x pipe, diode dynamics DRLs 1LE suede steering wheel, mighty mouse CC.
Sinister10 is offline   Reply With Quote
Old 08-08-2018, 02:22 PM   #8
LsxDoctor
12 year LS1 Tech Member
Drives: 2010 ss 391ci LS3
You did a good job! Looks great!
391 cube LS3, TSP F-35 cam, ported heads, Rod Mod, 1-7/8" LT's, blah blah blah
LsxDoctor is offline   Reply With Quote
Old 08-08-2018, 03:14 PM   #9
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2014 Camaro 1SS RS SIM
that looks awesome, braver man than me to cut up a hood!
2014 SS - L99 1SS/RS - "AleSSandra"
SSEssence is offline   Reply With Quote
Old 08-08-2018, 03:42 PM   #10
BLU DUCE
BLU DUCE's Avatar
It does look awesome. Very nice job. Do you have a drain pan installed also? I put the ZL1 look alike in mine. Had mine tapped up for a month and wrote across the hood. You ain't got the ball's to cut me. Did you remove the hood to cut it?
Old 08-08-2018, 03:44 PM   #11
Matt8892(2)
That’s what I keep getting told. Really wasn’t hard. After drilling no the first hole you know you’re committed and makes he rest of the job easier. Plus he cut doesn’t have to be 100 percent exact. There’s room for error
Old 08-08-2018, 03:50 PM   #12
Matt8892(2)
Gunna order the pan next week. Not worried about rain hitting the engine while it’s not moving. Plus there isn’t much rain called for here anyways this week
Old 08-08-2018, 03:54 PM   #13
xc_SS/RS
Drives: 2010 Camaro SS/RS
looks good! i did mine too and that first cut made me so nervous. but as you said once you make the first hole or cut you're committed.
i don't run with the tray during the spring, summer, and fall. i do install it in the winter to help keep things a little more toasty under the hood
2010 2SS/RS
Z/28 intake, ported TB, rod-mod intake, speed engineering LT's w/ cats, 3" catback, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, 160* t-stat, HP Tuners, some suspension work, stickers and a little weight loss. 12.72 @112.36
xc_SS/RS is offline   Reply With Quote
Old 08-08-2018, 03:58 PM   #14
Matt8892(2)
How often do you drive in rain? My car pretty much never sees rain while driving other than being parked. So not to sure how worried I should be about water in there.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
