Old 12-16-2018, 06:49 PM   #1
chris41
Drives: 2011 Camaro SS convertible
MyLink faceplate poor fit
I have a 2011 Camaro and just did the MyLink Nav upgrade. Upon installing the faceplate, I notice I can't get the screen to lock tightly in place and have a gap around mostly the top between the radio and the dash. The fit on the passenger side is worse. Is there something I'm not doing correctly?
chris41 is offline   Reply With Quote
Old 12-16-2018, 07:14 PM   #2
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
So I have not installed this unit, but I just did an aftermarket radio install using the pac kit. I found that getting everything to fit behind the radio was a challenge. Had I known that the space was so limited, I would have installed a multimedia radio (much more shallow than a regular double din with a CD drive). Do you think you could get some of the wiring back tighter?
45thCamaro is offline   Reply With Quote
Old 12-16-2018, 07:31 PM   #3
hammdo
'It's an experiment'
hammdo's Avatar
Did you trim the top 2 guides/supports on top of the mylink that were used by the old style radio?
https://www.camaro5.com/forums/showp...5&postcount=57
Also you should have trimmed the rear area also (see where I have blue tape).
Had to trim the gauges/pod area to fit correctly...
Did you buy Gen5Diy’s kit?
-Don
747 RWHP 794 RWTQ
Old 12-16-2018, 10:40 PM   #4
chris41
I have the upper supports and the receiver fits fine. I did trim the back too. Does the bottom go in first (by the 2 bolts) and then swings up to snap in?
Old 12-19-2018, 03:24 AM   #5
chris41
So spoke with Gen5DIY and had to remove my center console (again) for the faceplate to fit well. Really like this upgrade!
Old 12-19-2018, 09:01 PM   #6
Leo72793
Drives: 2011 2SS/RS
you dont have the bottom properly inserted. remove and reinsert and adjust
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 12-20-2018, 12:30 PM   #7
Roader
Drives: Camaro
Looks like you fixed it but I had the same issue when I did the install. Eventually I took a break and came back and it popped in.
Roader is offline   Reply With Quote
Old 12-21-2018, 10:08 AM   #8
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
-Don
He pieced it together and did a good job of it, and we are here to help if we can.
Old 12-24-2018, 10:12 PM   #9
johnkeo
Drives: nice
nice to know the tips on how to fix from the experts and appreciate their efforts
johnkeo is offline   Reply With Quote
