Old 01-03-2019, 12:10 PM   #1
Sturgill_SS
Sturgill_SS's Avatar
Drives: 2010 Camaro SS
335's out back with no problem?
This came up for sale on Facebook and I think it looks amazing. Thinking about doing the same exact thing with mine.. 335's just seem awfully wide. Has anybody else tried this? He said they fit no problem. Lowered an inch..
F35 Cam / LOD X-1 Manifold / SLP CAI / LS7 Lifters / 3.91 Gears / Hooker Blackheart Exhaust / TSP Headers / SLP Underdrive Pulley / MGW STS / Trunnions and all that other fun stuff....
Sturgill_SS is offline   Reply With Quote
Old 01-03-2019, 01:01 PM   #2
rshelar
rshelar's Avatar
Drives: 2017 1SS auto vert Nightfall Gray
The widest that you usually see is 315. 335 seems to be pushing it. I went to just 295 with the Eibach pro line springs with one inch drop. No problem unless you hit a hole on the highway. BAM!
rshelar is offline   Reply With Quote
Old 01-03-2019, 01:12 PM   #3
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
What size wheel, how wide?
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 01-03-2019, 01:57 PM   #4
Spec
Drives: 2010 Camaro 1SS LS3
Barely noticeable difference from 315's, but its there....
There's so much room in them rear wheel wells, that I wouldn't be surprised at all that 335's would fit without issue...
Not sure if the difference in profile would actually be worth their price. I can get the 315 NT555 G2's for about 250. I reckon a 335 would be about double that..... I say stick with the 315's.
Spec is offline   Reply With Quote
Old 01-03-2019, 02:20 PM   #5
Roader
Drives: Camaro
Is there a reason you want a 335 over a 305/315?
Roader is offline   Reply With Quote
Old 01-03-2019, 02:43 PM   #6
Sturgill_SS
I'll probably stick to 315. Just curious about the 335.. 11 inch rim
Old 01-03-2019, 03:00 PM   #7
HDRDTD
Minimum 11" wheel, not sure what offset you'll need.
Old 01-03-2019, 03:33 PM   #8
NC_SS
NC_SS's Avatar
Drives: 2012 M6 Camaro SS (RIP)
There is no logical reason to go wider than 305 unless you're making 500+ at the wheels
That side, steam rollers always add an incredible looking stance to any go fast machine no matter the power it makes.
Speed engineering 1 7/8 LTs, CAI inc Cold Air Intake, offroad connectors, Solo performance axle back with J pipes, tune, and in need of a driver mod LOL
NC_SS is offline   Reply With Quote
Old 01-03-2019, 04:14 PM   #9
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
It all depends on tire manufacturer too. The way they measure the width doesn't have 100% control over what actually sticks out the side. take two of the same size tires from different manufacturers and measure them and you will get different results
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 01-03-2019, 04:23 PM   #10
scott's45
Scott's45
scott's45's Avatar
Drives: 2012 2SS 45th Anniversary
i think the most important thing to remember is the overall diameter of the tires. if you run 335's in the rear, what do you have to run on the front so the computer doesn't throw a fit. and will the front rub with those tires.
2012 2SS 45th Anniversary, Hurst short throw shifter, Stainless Power LT headers, high flow cats, SW Retro Chambered 3" cat back, CAI, Heritage grill, tinted windows, red/silver hash stripes, AAC LED sidemarkers, blacked out turn signals/tail lights, splash guards. 402RWHP
scott's45 is offline   Reply With Quote
Old 01-03-2019, 05:26 PM   #11
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Important to note too that 335 over 315 is only less than 7/16 difference each side different. I dont think its an issue.
2014 2SS/RS LS3/M6
Old 01-03-2019, 06:17 PM   #12
Roader
Drives: Camaro
What?
Old 01-03-2019, 06:25 PM   #13
Chris49066SS
Drives: 2010 SS L99
Originally Posted by Roader View Post
What?
Old 01-03-2019, 06:30 PM   #14
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
What?
I think what he means is a 335 tire doesn't come in a comparable side wall height percentage to match the outside diameter to an available front tire diameter
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
