02-21-2017, 06:03 PM | #1 |
Drives: 2016 SS Convertible Join Date: Sep 2016
Borla axle back S-type - fit convertible?
Does anybody know if the Borla axle back exhaust fit the convertible?
They say except convertibles on the full cat back and doesn't have that in the description of the axle back like the 11922. So I'm thinking it would fit. But not entirely sure - I guess I could call and ask them. But has anybody tried it? |
02-22-2017, 10:23 AM | #2 |
Drives: S O L D Join Date: Aug 2016
I purchased the Borla 16 Chevy Camaro SS 6.2L w/ Dual NPP S-Type 11924. It is axle back. I checked with Borla, and they advised it will fit. I have it in my garage, and it will be installed in about a month when I "unwinterize" my car.
Judging by the parts, it appears it is a pretty straight forward switch out with the existing mufflers. The cat back will NOT fit, due to extra structure features on the under body of the convertible. I am trusting the S-Type 11924 axle back will fit.
Club F1FTY
2017 2SS 50th Anniversary Convertible Borla S-Type exhaust NPP| GM CAI | Color matched GM side skirts | Color matched 3rd brake light | Big Worm Graphics smoked out tail lights & rear reflectors | Oracle ghosted side markers | LED License plate bulbs | Door striker covers | Jam handle | Engine emblems from RiverCity Creations | 50th Center Console | Black bow ties | Hawk Performance ceramic brake pads | ZL1 Start button | CQuartz ceramic paint finish | Novistretch bra | S O L D |
02-22-2017, 03:07 PM | #3 |
Perfect. That's what I figured. Thanks.
04-27-2017, 10:41 AM | #4 |
Instagram: @SSAVAGEVERT
Drives: 2016 SS M6 Vert Join Date: Jan 2016
Does anyone have a picture of the convertible undercarriage?
2.9L Whipple | Compstar Rods, Diamond Pistons & GPI Cam | Mantic Triple Disc | Corsa Performance Exhaust | DSX Aux Pump | LT4 Fuel System | BMR Lowering Springs | ZL1 OEM Conversion | 360 Customs Built | And More!
Click & Follow My Build |
04-27-2017, 10:49 PM | #5 |
Drives: 2017 Camaro 2SS Fifty Edition Join Date: Jan 2017
you can see part of it. There is a cross brace that is not under coupes
04-27-2017, 10:50 PM | #6 |
But the cross member is on top of everything, so a Catback still should work
04-28-2017, 09:14 AM | #7 |
I thought so to, but when I spoke to Borla they said "No go". Did not want to "chance it", so I went with the axle back. Had it installed two weeks ago. VERY VERY happy with it.......
Club F1FTY
04-28-2017, 09:19 AM | #8 |
Summit Racing is 30 min from my house. I may buy the Catback and if it doesn't fit, I'll just return it. Usually they say it doesn't fit Bc they haven't tested it on Convertible
04-28-2017, 11:13 AM | #9 | |
Mike
Club F1FTY
04-28-2017, 12:00 PM | #10 |
That axle back will fit, it won't interfere with the cross member supports. I would bet you could even do their mid pipes because it's the same diameter as stock.
04-28-2017, 12:02 PM | #11 |
This is true, I had a different car and installed a cat back that was about 1/2" larger pipe diameter and it still fit, it's just that it touched the cross supports in the back, they fit and I could get the supports back on, it's just that most people would not like to see the supports touching their exhaust like that so they say "it doesn't fit"
04-28-2017, 12:22 PM | #12 |
Drives: 2023 2SS Convertible Join Date: May 2009
I wouldn't think there would be an issue on the axle back. Be careful with the cat-back, though. Those "Flat Pipes" that everyone complains about on the coupe are in there to clear the bracing on the convertible (so GM can use the same exhaust). If you put a 3" pipe in there you would probably be rattling.
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
05-18-2017, 05:31 AM | #13 | |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
In Stealth mode, how much louder is it than the stock NPP set up?
I hope the 6th gen Camaro has a melodious horn trumpet. I'll tootel it at the ladies, yelling out "Hi hi." - RenegadeXR
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
05-18-2017, 07:52 AM | #14 | ||
Club F1FTY
