08-28-2017, 08:49 PM | #1 |
Drives: 2013 Camaro 2LT/RS Join Date: May 2017
Got Caught In A Flooded Highway - How Worried Should I Be?
Hey all,
Got caught in a flood on I-696 today and the police wouldn't let us turn around so we had to drive through water. Drove through water up to the bottom of my door for about 100 yards car never stalled never bucked anything and there doesn't appear to be ANY water in my oil/nothing electrical wrong/no warning lights. Drove the car 50 more miles before stopping and it ran absolutely fine. How worried should I be? Changing the oil tomorrow just to be safe but should I worry about the trans/rear diff/etc? 2013 LFX A6.
2019 Chevy Colorado LT
2013 Camaro 2LT/RS "Christine" - SOLD 10/15/18 1993 Jeep Wrangler YJ 1993 GMC K1500 "Old Blue" 1943 Farmall A |
08-28-2017, 08:50 PM | #2 |
Pic2
08-28-2017, 08:51 PM | #3 |
3
08-28-2017, 10:15 PM | #4 |
Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
Water in your engine shouldn't be a problem. I'd be more concerned about water coming in past the door gaskets and getting into the carpet. Check the carpet around the doors and if it's wet--really wet--I'd pull it back to let it dry thoroughly.
Meh
08-28-2017, 10:22 PM | #5 |
Carpet was bone dry all around both doors, think I'm pretty safe there. Never had to go through water like that in this car, was just sort of panicking. Thanks for some reassurance.
08-28-2017, 10:27 PM | #6 |
Drives: 2018 1SS M6 Join Date: Nov 2014
I highly doubt you had water intrusion into the oil. If oil isn't leaking out, not much chance of water leaking in. Now, if you got water in through the intake, that would be different, however you would've probably stalled at the point, or least ran like crap.
Even if you did get a small amount of water in the crankcase, it would've most likely burned off by the time you got home. Moisture in the oil happens often when taking short trips where the car doesn't hit full temp for long enough time, condensation will form. This is why too many short trips is bad for an engine. As far as the rest, you should be alright. |
08-29-2017, 12:21 AM | #7 |
Drives: 2014 2SS blue Join Date: Jun 2016
I think you'll be fine.
08-29-2017, 07:49 AM | #8 |
Drives: 2013 Camaro SS Join Date: Oct 2016
I'll be damned if they are going to make me drive through that. I would pull over and say the car stalled get me a flatbed tow truck to drive my car through. But then again my car hasn't seen a wet road other than the carwash since..... ever.
Glad to hear you made it through ok and hopefully with no long term issues to the car. |
08-29-2017, 09:02 AM | #9 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
08-29-2017, 09:50 AM | #10 |
Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
This! if carpet dry as you say.... you are fine.
08-29-2017, 10:00 AM | #11 |
Thank you for all the responses, you're all making me feel a lot better about the whole thing. Should I bother checking the trans fluid/rear diff fluid? I never stopped driving and was only going through the water for approximately 60 seconds at 5mph and the car hasn't acted up at in the ~150 miles I've driven since.
08-29-2017, 10:16 AM | #12 | |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
08-29-2017, 12:13 PM | #13 |
Drives: Race Car Join Date: Sep 2009
You should be fine! The Trans & Diff are sealed so definitely no issues. If you had sucked a lot of Water in the Intake, you motor would have Hydro-Locked. Since that didn't happen you are good.
the Good Thing is you Camaro got an underbody wash! |
08-29-2017, 12:26 PM | #14 |
Drives: 2015 BLK 1SS LS3 M6 NPP Join Date: Aug 2015
Your issues would have shown up at this point. If you have not found wet carpet, you're fine op.
2015 BLK/BLK 1SS LS3 M6, NPP, NAV, Tint
2017 GMC Acadia 1983 Monte Carlo 5.3 LS Swap |
