12-11-2011, 01:07 PM | #1 |
Let's go Rangers!
Engine failures/low oil levels. Post your current results!
All this talk about engine failures and low oil levels, I checked mine today (as I do every fill-up), here are some pic & stats. Car was driven to hot then shut off for 5 minutes when checked.
Model: 2011 2LT/RS Build Date: 02/11 Current miles: 5494 Miles on current oil: 3050 1st oil change: 2444 (dealer changed). Will change at 4K intervals at this point Oil used: Mobile 1 (6 quarts) Engine Mods: Vmax TB, CAI (CAI), RX Catch Can, ADM Scoop & Rota-Fab washer kit, MRT 2.0. Daily driver in Florida heat. 100% sport mode and I’d say somewhat hard, no redlining but frequently hit 5K. About 50/50 hw/city I am seeing little to no loss, and decent color. As you can see my oil level remains in the top cross-hairs. |
12-11-2011, 08:09 PM | #2 |
Track > 1/4 Mile
I haven't seen any loss in oil level. I just ticked over to 26,000 miles and the car was built August 2009. I use synthetic oil and change it every 3,000-3,500 miles.
12-11-2011, 08:12 PM | #3 |
Drives: 2011 LS Join Date: Oct 2010
Starting to feel like "Ground Hog Day". We have like 4 of these threads already.
12-11-2011, 08:13 PM | #4 |
Drives: 2010 Camaro 1lt.rs. Bottle fed Join Date: Nov 2011
I felt bad about starting my thread on this but I feel like that was the way to get the best answers. it worked lol
12-11-2011, 08:43 PM | #5 |
Winners find a way
Drives: 2010 2LT/RS M6 Join Date: Jun 2010
!4.9K mi, changed at 2, 6 and 12K with amsoil. Build Aug 09
Added 1/2 qt up to now, about 1/3 of that was inside RX catch can. Frequent 6K+ runs. I would say almost no oil usage |
12-11-2011, 09:09 PM | #6 |
Your thread has been VERY useful. Adding more is just beating a dead horse. It all will be covered in the other threads.
12-12-2011, 07:38 PM | #7 |
i use mobile one full synthetic and change it every 3k. i use stp oil filter. not a big fan of fram oil filters. i know it says every 5k miles to change your oil but i never can let it go that long.
12-13-2011, 10:30 AM | #8 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
OK, so sometimes my car may not make it out much due to weather, and now that winter is upon us it will make it out even less.
The other day (after car had been sitting for at least 5 days) without starting beforehand I measured the oil. It was halfway in the middle of the markers. Took her out and drove it. The next day I checked my oil again. Now it was at the top marker so I didn't add any of course. Now, I've done oil changes since I was old enough to do the work, and I know it is usually OK to check the oil without the need to start up before hand (unless of course you just changed your oil and you need to cycle it first), but if my car has been sitting for an extended period, should I start it up for 30 sec to a minute before hand and then check?
2010 Camaro 1LT V6 (Sold. I will miss her!) |
12-13-2011, 11:05 AM | #9 |
Wind Rider
Drives: ZL1 19 White; Jeep 5.7 GC 15 Join Date: Jan 2010
Its like the H1N1 virus is back and everyone fears to get it
Im not Gray any more !!
12-13-2011, 11:13 AM | #10 |
Not to sound ignorant, but is the engine failure supposedly due to low oil or bearing issues? I've heard both reading the various threads..
12-13-2011, 11:14 AM | #11 |
Lol right. You can avoid it. Unlike h1n1. But this shouldn't scare anyone it is just inform them that it does happen and it will happen with out a low oil level light.
12-13-2011, 11:15 AM | #12 |
From my understanding the low oil causes the bearing to break which then in turn stops your motor.
12-13-2011, 11:18 AM | #13 | |
Wind Rider
12-13-2011, 11:20 AM | #14 |
Could of used them 15k miles ago! Lol
Similar Threads | ||||
A Look at GM's Oil Life Monitoring System | franknbeans | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 166 | 05-23-2014 06:31 PM |
New GM Oil Spec - dexos 1 | Sidewinder | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 17 | 01-06-2011 11:52 AM |
First oil change? | Fogey | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 27 | 09-18-2010 06:50 AM |
The BEST Break for a new car. "very long" | Darin Morgan | General Automotive + Other Cars Discussion | 346 | 02-04-2010 06:49 PM |
Oil Change Ramp | mjlash22 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 17 | 01-21-2010 10:40 PM |
