Old 12-04-2017, 11:30 AM   #1
CGT
Drives: 2011 SSm6
Lifting heads, Pressurizing cooling system
Just curious at what boost level any of you have experienced this at. With stock bolts etc. ?
CGT is offline   Reply With Quote
Old 12-04-2017, 12:23 PM   #2
CGbambam
Drives: 2011 Camaro 2SS
Stock bolts not sure, but 24 psi on arp head studs i lifted mine. Well more like the headgasket melted and made a hole threw the head but you get my point
CGbambam is offline   Reply With Quote
Old 12-04-2017, 12:50 PM   #3
AGP Turbo
Drives: All things Turbocharged
'With stock bolts etc.?'-
So I assume you must be talking about a pretty much stock engine. If you have high octane fuel and a good safe tune, then your pistons will usually be fine and your rods will bend before the heads will lift. Heads lifting seems like more of a bad tune, too low octane problem. Pistons would likely break before the heads would lift too.
And without enough octane your pistons are for sure the first thing to go.
AGP Turbo is offline   Reply With Quote
Old 12-04-2017, 01:26 PM   #4
CGT
Drives: 2011 SSm6
TVS1900 ported, stock ls3 shortblock, 8.6 x 2.38 pulleys, ported heads, cam, etc. Makes 14lbs on E85. 800rwhp SAE. I've been getting some mystery air pockets in my cooling system. Just trying to figure out whats going on. Thanks for the input.
Old 12-04-2017, 01:53 PM   #5
AGP Turbo
The heads came off and it went back together with stock head bolts? That's rarely done right. The holes have to be chased out and cleaned to like new for the torque specs to be accurate. Head studs make that irreverent and are stronger too.
Old 12-04-2017, 01:57 PM   #6
Punisher_ATX
Drives: 2010 SS
ARP studs and Athena Ring Gaskets are good for 30+ psi. Just sayin
Punisher_ATX is offline   Reply With Quote
Old 12-04-2017, 02:32 PM   #7
CGT
Drives: 2011 SSm6
It was a clean and accurate install, done by myself. I am very meticulous. But you never know I guess. I'm just trying to get some ideas. Thanks
Old 12-04-2017, 02:40 PM   #8
Punisher_ATX
Drives: 2010 SS
For reference i run 12psi LSA blower stock bolts.
Old 12-04-2017, 03:13 PM   #9
CGT
Drives: 2011 SSm6
Thanks for the info. I was at 11.8lbs for awhile with no issue like this. The last few pounds seems like is when this started happening. I'm still not convinced that it is lifting the heads, could be in denial I suppose.
Old 12-04-2017, 03:36 PM   #10
Punisher_ATX
Drives: 2010 SS
What type of blower? or turbo? A local guy with a D1 lifted his head and pushed coolant at 9psi
Old 12-04-2017, 03:48 PM   #11
CGT
Drives: 2011 SSm6
Ported, welded LSA blower.
Old 12-12-2017, 11:04 AM   #12
CGT
Drives: 2011 SSm6
Well, after playing with it some more, I'm farely convinced I'm lifting the heads a bit. No knock detected, AFR is right on, but manages to get an air pocket and overheat after a hard pass.
Has anyone had a similiar issue? And if so, does anyone feel head studs will really resolve it? Has anyone went from stock bolts to studs and resolved an issue? Just curious. Thanks
Old 12-13-2017, 03:16 AM   #13
Slickcas
Drives: 12' 2SS/RS LS3 IBM
Stock bolts seem to work for some. But at 14 psi I would pull the heads. Chase the threads. Clean all the mating surfaces up. Use LS9 Head gaskets. And ARP Head bolts. For the $$ hard to beat.
Also ARP bolts can be reused. Stock bolts (stretch boats)CAN NOT.
You can step up to ARP studs , also there are a few high end MLS gaskets out there.
But for us normal crazy people running less then 20psi it’s just not needed.
Slickcas is offline   Reply With Quote
Old 12-15-2017, 07:08 AM   #14
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
It does sound like you are lifting the heads.
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
