#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
Old 10-15-2018, 07:04 PM   #1
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
MBRP Catback CEL
Hey gents. First post so bear with me....
Just installed MBRP Race Catback on my 1LE M6.
Got the CEL this morning but it runs fine. Any ideas? Obviously no AFM in the M6. But curious if the NPP motors are handed and maybe I got them mixed up.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
Old 10-16-2018, 06:03 AM   #2
crosive
Drives: 18 zl1
do you have any way to see what the cel is?
I don't think the npp valves are handed, but I could be mistaken. you could unplug fuse 52 and disable them altogether if that makes you feel better. I don't think a cel has ever been thrown for those.
crosive is offline   Reply With Quote
Old 10-16-2018, 07:58 PM   #3
BruceWayne1LE
Bank 2 oxygen sensor is running rich? Any ideas? Anyone?
492WHP 473WTQ
Old 10-17-2018, 06:35 AM   #4
VinnAY
Drives: 18 1SS/1LE
Only thing related to a catback that I can think of is that there's a leak somewhere in the system. I'd relook at the joints and clamp, reposition/tighten and see if that get's you anywhere.
VinnAY is offline   Reply With Quote
Old 10-17-2018, 07:52 AM   #5
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
yeah a catback shoould NOT being throwing a CEL, check your clamps, verify there is no leaks! "Bank" errors are related to your 02 sensors so if you removed them make sure they are tightened and plugged in.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 10-18-2018, 01:03 PM   #6
BruceWayne1LE
Checked everything. Tighter than prom night. Idk how but maybe that sensor is bad? Im lost on this one. The only other thing i did when installing the exhaust was the catch can but idk how that would affect a rich code.
492WHP 473WTQ
Old 10-18-2018, 01:36 PM   #7
MP3BOOSTED
MP3BOOSTED's Avatar
nope, catch can wouldn't do it, have you tried to reset the battery?
Old 10-18-2018, 01:46 PM   #8
coruiz
Drives: 2018 Camaro 2SS Hyper Blue
you def have a leak somewhere, probably on the passenger side. Work front to back, one clamp at a time and re-check everything
2018 Camaro 2SS
| Hyper Blue Metallic | A8 | NPP | MRC | NAV | HUD | ATAK |
coruiz is offline   Reply With Quote
Old 10-18-2018, 01:55 PM   #9
Tech@Flowmaster
Tech@Flowmaster's Avatar
Drives: 2016 Camaro SS
Welcome, as others have stated check for exhaust leaks first. While underneath the vehicle swap the O2's from left to right (lot's of rust penetrant before attempting removal and add anti-seize to threads before re-installation). During removal pay close attention for damage to the wiring or harness on the sensor in question. Clear the codes and if the code jumps to the opposite bank you have your culprit. If the code doesn't jump sides I would recommend calling the manufacturer directly for additional assistance.
- Jason @ Flowmaster
Tech@Flowmaster is offline   Reply With Quote
Old 10-18-2018, 07:15 PM   #10
BruceWayne1LE
OK im headed back up to my buddies shop. Gonna go through it from headers to tips. Im gonna take out the sensor take a look at it then swap sides. If it turned out to be a leak will the code just go away or do i need to reset the ECU?
492WHP 473WTQ
Old 10-21-2018, 11:03 PM   #11
BruceWayne1LE
So ran tgrough the whole exhuast. Tightened everything except the headers. Switched the O2 sensors from left to right. Still got codes. Now its P02099 and P0430. Im about to lost my mind on this one. Going to the dealership tomorrow and getting new collector gaskets and a new O2 sensor and covering all my bases.
492WHP 473WTQ
Old 01-27-2019, 11:10 PM   #12
dfxrte
Drives: 22 ZL1 M6
did you ever find out the issue?
dfxrte is offline   Reply With Quote
Old 03-31-2019, 11:17 PM   #13
BruceWayne1LE
I replaced the gasket behind the passenger secondary car and the O2 sender. Tightened the holy F*** out of everything. No more code.
492WHP 473WTQ
