07-30-2013, 05:40 PM | #1 |
Drives: 1970 Pontiac GTO Join Date: Jan 2012
LS High volume GMPP oil pump
Is this thing okay for a ls3?
part number 17801830 Its essentially a slightly tweaked LS6 oil pump from what I read? Has anyone run this in their ls3? http://paceperformance.com/i-6255418...-pump-kit.html |
07-30-2013, 07:01 PM | #2 |
Drives: 2010 Cyber Grey Camaro SS (LS3) Join Date: Mar 2010
Honestly man, I wouldn't even waste your money when there is better that can be had. My advice? get the Melling 10296 H/V Oil pump and don't look back.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
07-31-2013, 10:19 PM | #3 |
I put the GMPP piece in my car, and haven't looked back either I did do a little work to it with some sanding rolls and files before I installed though, so, I guess I can't say that it is "stock", either. Either way, you probably can't go wrong. I'm sure there are horror stories for both pieces. Good luck!
07-31-2013, 11:06 PM | #4 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
More horror stories with the GM pieces than the melling, mellings are already blueprinted and built with better materials.
Thread Tools | |
