10-13-2018, 09:30 AM | #15 | |
Check your grounds. Also, check everything to do with that starter. The alternator line going to it and everything. Electrical gremlins are the worst. Just takes time to track them down. Try calling some junk yards and see if you can find a fuse box and swap em out. |
10-15-2018, 08:08 PM | #16 |
Drives: 2000 SS Join Date: May 2011
Ok so the starter was dead. I replaced it with a brand new one. Started perfect. Ran for about 30 min. Went to start it again and acted like a dead starter again... So I think I've pinned it to that but what's causing the starter to die. I tried to keep turning it over and the starter started smoking bad. So I know this one is fried too. But what's killing them.... Anyone had this before ?
10-16-2018, 02:14 AM | #17 |
Drives: 2015 Camaro 2SS Join Date: Oct 2016
Might be time to turn the engine over manually, make sure nothings tight internally.
Have you checked there is a good engine earth? |
10-31-2018, 02:41 PM | #18 |
Does anyone know the 2 small wires connected on the battery positive terminal in the trunk... What they are for ?
02-09-2019, 06:47 PM | #19 | |
Drives: 2010 Camaro SS Join Date: Feb 2019
My ecm 1 fuse keeps blowing
Bro did you ever find out what the problem was? My ecm 1 fuse blows when I try to start the car sometimes, then I switch the fuse and wait around 10 minutes and the car is up and running. It blows every 5 or 6 days, but I changed my starter and battery, but I still have the fuse blow. |
