#Camaro6
Old 11-15-2017, 04:32 PM   #1
Steelankles
Steelankles's Avatar
Drives: 2017 Camaro SS 1LE
Lifting 2017 Camaro on a lift without jackpads is it possible?
Seems a little nuts to have to spend $130 on jackpads, when I can lift any other car for free?
2020 ZL1 1LE Crush
2017 SS 1LE Hyper Blue sold :(
1995 Mustang GT 427ci Road race car
Youtube: Steelankles
https://youtube.com/c/steelankles
Steelankles is offline   Reply With Quote
Old 11-15-2017, 04:36 PM   #2
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
there are other “pinch weld protectors” that you can use temporarily on each corner, but none that I’m aware of that attach permanently like the ZL1 add-ons. The lack of easily accessible and useable lifting AND jack stand points on the car is definitely one of the 6g shortcomings.
ninetres is offline   Reply With Quote
Old 11-15-2017, 04:37 PM   #3
Mr. Meh
Drives: Sold
You dont' have to spend 130.00 on jack pads or frame rail adapters.
I and several others have used the 4 - 12.00 frame rail pucks from Amazon and they're just fine.
they're not pretty anodized alum and able to stay on the car, but I'm not paying an additional 100.00 for that.
Mr. Meh is offline   Reply With Quote
Old 11-15-2017, 04:55 PM   #4
Generallee0179
Drives: 2017 SS
I made my own frame rail jacks by cutting slits into pieces of wood. It worked well enough to get the car on jack stands. DO NOT do this if you're intending on getting under the car without jack stands.
Generallee0179 is offline   Reply With Quote
Old 11-15-2017, 05:05 PM   #5
wwiiavfan
Drives: 2017 1SS Hyper Blue
The ZL1 pads are for the track rats who are jacking up their car all the time. An appropriately thick chunk of metal with a groove cut in it will work fine for the rest of us.
wwiiavfan is offline   Reply With Quote
Old 11-15-2017, 05:32 PM   #6
Steelankles
Do guys have link to the cheaper options that work i ordered a skip shift eliminator that i want to install. Thanks
2020 ZL1 1LE Crush
Old 11-15-2017, 05:48 PM   #7
chrest
chrest's Avatar
Drives: 2017 Camaro 2SS
i have the rubber pinch weld pucks from amazon that work well
2017 NGM 2SS NPP M6 MRC
Vortech SC, 2" TSP LT No Cats, Borla X, Eibach,
Hurst shifter
603hp/547tq
chrest is offline   Reply With Quote
Old 11-15-2017, 07:23 PM   #8
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
Same. Search amazon pinch weld jack pads. $4 work great
Nationwide Turf
"artificial turf factory"
lawdogg149 is offline   Reply With Quote
Old 11-15-2017, 07:45 PM   #9
argus
argus's Avatar
Drives: 18 GMC Sierra 3500HD SLT Duramax
I use this one on my vert and it works perfectly:
https://www.amazon.com/gp/product/B01MA232WY/
2017 2SS Convertible Auto Summit White/Jet Black (Wife’s) photos garage
2018 GMC Sierra 3500HD 4WD CCSB SLT White Frost Tricoat/Dark Ash (Mine) photos garage
argus is offline   Reply With Quote
Old 11-16-2017, 06:18 AM   #10
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Got a piece of scrap crating wood (already has a U shape channel cut into it) from Lowe's. Used a hand saw to make a deeper cut and cut it lengthwise to fit my jack. 5 Minutes, $0 to make.
kwav8r is offline   Reply With Quote
Old 11-16-2017, 11:32 AM   #11
Steelankles
Thank you for the info i used the link above and ordered 4. iwanted to make sure i got the right one since there was a lot of options.
2020 ZL1 1LE Crush
Old 11-17-2017, 11:43 AM   #12
Blazin383
Blazin383's Avatar
Drives: 2016 SS
Before I bought my pucks, I just cut a piece of 2x4 about 4" long and cut a groove down the middle of it about 3/4" deep. Worked perfectly with my floor jack, but I wouldn't suggest doing that if your using one of the cheap floor jacks with the 2" lifting plate. You probably want a jack with a nice 4"-5" lifting plate to distribute the pressure on the 2x4.
Blazin383 is offline   Reply With Quote
Old 11-17-2017, 12:23 PM   #13
diirk
diirk's Avatar
Drives: 2016 Camaro SS
honestly, if you're just getting a service done or something similar on a lift, the pinch weld is not going to bend under occasional use, even without a pinch weld protector. They're more than strong enough. It's when people are using a floor jack and jacking one side up then the other and putting extra lateral pressure on the pinch weld that you run a risk of bending it.
16 2SS 6MT NPP White | MRR | ACT | JBA | SCT | C7C
04 Ram 2500 CDT 4x4 Quad
91 Miata 1.8 Feal Wilwood Track Car
1morproject
diirk is offline   Reply With Quote
Old 11-17-2017, 01:52 PM   #14
SSDanny
Drives: 2017 Camaro SS M6
Just cut up a piece of wood lol. Works fine.
2017 Camaro SS - Kooks Long Tube Headers 1-7/8th - EFI Flex Fuel Kit - Megan Racing Coilovers - FORGESTAR F14's 20x9.5 & 20x11
SSDanny is offline   Reply With Quote
