Old 07-05-2018, 01:29 PM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
Maxing out the Vortech V3Si on ESS Tuning Kit
After reviewing all my logs and speaking with ESS Tuning, it appears I can spin this blower a little faster and still be under the max rpm allowed by Vortech.
I'm currently seeing a max of 10.5-11.3 psi on a 95mm pulley. All of my logs, including dyno runs (in very hot dyno rooms) show my hottest IAT being 104 degrees F. On the street, I rarely see over 102F peak.
My timing tapers down to 14.5 degrees up near redline. I'm still running 93 octane and see zero KR. I'm thinking about dropping down to a 93mm pulley, to gain 2 more pounds of boost. I have a modified FPCM and see a solid 58 psi to redline, so I think on 93, I have plenty of fuel.
Does anyone see a reason not to pulley down ($129) and retune ($400)?
Thanks
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 07-05-2018, 01:37 PM   #2
eLeSthree
Ambient temps in the dyno rooms are about 95degrees and on the street its been around 80-84 lately.
1158whp 1017wtq.
630whp 658wtq
Old 07-05-2018, 02:48 PM   #3
hillshooter
Drives: 2015 Camaro SS commemorative
Man put some Vp110 in that thing and let it eat !
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
Old 07-05-2018, 04:49 PM   #4
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Sell it and put the money toward a bigger blower. You are already wanting more power.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 07-05-2018, 08:13 PM   #5
Camaro T
Drives: 13 IOM SS/RS LS3 Blown
I think your trying to blow that motor to give yourself an excuse to build something better, lol.
Camaro T is offline   Reply With Quote
Old 07-05-2018, 09:23 PM   #6
eLeSthree
I cant say anything at this point, but something like that is in the works.
I just wanna see what this little thing can do first. For $530 i could pick up 30-40whp and be at a comfortable stock block limit.
1158whp 1017wtq.
630whp 658wtq
Old 07-05-2018, 09:25 PM   #7
eLeSthree
Since the belt is the same for 95 and 93mm pulley, i had considered doing a race gas tune on the smaller pulley. Only takes a few mins to swap it out and flash the tune for race days.
1158whp 1017wtq.
630whp 658wtq
Old 07-06-2018, 06:11 AM   #8
eLeSthree
Theres a lot of guys making a ton more power than me on the stock block. Only 38k on mine, hope it last a long long time.
1158whp 1017wtq.
630whp 658wtq
Old 07-06-2018, 08:43 AM   #9
bct10985
17psi from a ysi-b on my stock bottom end ls3. 9.6@145 mph in the 1/4.
Old 07-06-2018, 09:17 AM   #10
Punisher_ATX
Drives: 2010 SS
If you get to the point that you want to upgrade I can get a pretty good price on a YSI head unit and oil lines for it.
Punisher_ATX is offline   Reply With Quote
Old 07-06-2018, 05:24 PM   #11
eLeSthree
Appreciate that, but I have something in the works but it might take a while.
So if there is no one that sees a problem with the pulley change a retune, I guess I'll order it. My fuel system seems to be perfectly fine on 93, don't see why it couldn't handle another 40hp. We'll see.
1158whp 1017wtq.
630whp 658wtq
Old 07-07-2018, 07:12 AM   #12
thecarter0
Drives: 2010 Camaro SS
What kind of dyno?
thecarter0 is offline   Reply With Quote
Old 07-09-2018, 12:20 PM   #13
eLeSthree
Originally Posted by thecarter0 View Post
What kind of dyno?
Not sure why it matters, but it was tuned by Redline Motorsports.net on their Land and Sea Dynomite. Look them up.
I've got 407 miles on the new RXT1200 clutch. Almost done with the break in....
1158whp 1017wtq.
630whp 658wtq
Old 07-17-2018, 05:18 AM   #14
Slickcas
Drives: 12' 2SS/RS LS3 IBM
The little V3si is not to bad lol. Just run a bunch of 10.2s at the Camaro fest with it. I ran across the scales at the fest and weighed 4140 pounds with me in it. Full interior , stock front wheels and 18” MT tires out back.
Slickcas is offline   Reply With Quote
