07-08-2018, 04:10 PM | #1 |
Help guys. 2015 1LE
Stabiltrak service light on, T/C light, check engine light all on at the same time. Also tach stopped working. 25K miles. Battery issue?
55277502646__0EDE30E2-1494-42C3-9278-49273D308BF1.JPG |
07-08-2018, 05:52 PM | #2 |
Drives: 14 Silverado LTZ 4wd 5.3 Join Date: Jul 2012
Did you pull the check engine codes?
2014 Silverado LTZ 5.3
Sold: 95 Taurus SE 00 Z28 A4 06 TBSS 06 GTO M6 02 F150 01 B4C A4 05 GTO M6 02 Z28 M6 |
07-08-2018, 05:54 PM | #3 |
More details. What happened leading up to this state? Anything you can think of can help...
Is the car running? Making noise?
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR CTSV/ZL1 front calipers/rotors + G-Loc Forgestar CF-5 19x11 |
07-08-2018, 07:48 PM | #4 |
Sorry for not following up in a more timely manner. Pulled codes and found crank position sensor high voltage. Car was driven about 10 miles, stopped for 3-5 minutes and all of this occurred when I fired her back up. I think I have read about some TSB about the crank positioning sensor in the past. Thanks for all thoughts and responses. No noises, seemed a bit off when she restarted the first time.
07-08-2018, 08:49 PM | #5 |
Drives: 2015 Camaro 2ss/rs 1le redrock Join Date: Jan 2016
Possible crank sensor issue,signal back to cement, and anything to do with engine controls will disable Trac and abs systems ,check the wires to sensor
07-08-2018, 09:20 PM | #6 |
