Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Suspension / Chassis / Brakes
Old 12-25-2018, 02:57 PM   #1
Msports33
Msports33's Avatar
Drives: 214 SS 1LE SCCA T2
2-Z28 Front Struts -1" and 2-Rear Shocks -1/2" Sold
I have 2 front struts and two rear shocks. These were part of the GM original development program in 2014 for the Z-28 and are lowered 1 inch in front and 1/2" in back compared to stock, other than that they valving etc. is the same as stock.
Fronts:
The fronts have had the mount where they mount to the knuckle lowered -1".
The fronts have a hole in the bottom, and a hose to relieve pressure inside the inverse tube for better suspension compliance.
Rears:
The rears have had the lower spring mount machined for -1/2".
It also allows the rear suspension to not hit the shock bump stops and maintain rear geometry.
The reason the rear lowering is less to rake the car slightly for road course use (less oversteer). You can see pics of the car at www.msportsracing.com. You cannot see the rake.
They have approximately 1200 miles on them. No rain or salt. Looking for $850. Pic has another loose rear shock, not included (just sold separate). Freight/packing not included.
Msports33 is offline   Reply With Quote
Old 12-26-2018, 07:05 PM   #2
MX621
MX621's Avatar
Drives: 2014 z28
Would you sell just the single un used rear shock? I have a leaking damper on one of my rear shocks on my 2014 z/28?
MX621 is offline   Reply With Quote
Old 01-07-2019, 05:58 PM   #3
Msports33
Msports33's Avatar
Great upgrade for SS or 1LE
Old 01-07-2019, 11:48 PM   #4
93TAWicked1
Drives: Camaro
Damn I would love to have those springs!
2011 IOM RS/2SS. Manual, Eforce, Fuel mods, 3.25 pulley, Stainless Power headers, Borla exhaust, MGW shifter, Z28 suspension with stock front sway, ZL1 Brakes, ZL1 body kit and hood, rotofab
93TAWicked1 is offline   Reply With Quote
Old 01-08-2019, 08:37 AM   #5
Rando73
Rando73's Avatar
Drives: 2012 M6 ZL1
Still available?
2012 M6 Black , Roto Fab , Corsa Cat-Back....
Rando73 is offline   Reply With Quote
Old 01-08-2019, 10:07 AM   #6
bkevind
bkevind's Avatar
Drives: 2013 2SS RS 1LE
This is interesting. Any concerns with the slight lowering and the travel / valving of the dampers?
What did you do for camber with this setup?
Unrelated curiosity question -
What suspension did you move on to with your SCCA T2 setup?
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR
CTSV/ZL1 front calipers/rotors + G-Loc
Forgestar CF-5 19x11
bkevind is offline   Reply With Quote
Old 01-18-2019, 07:21 PM   #7
Msports33
Msports33's Avatar
yes!
Old 01-18-2019, 07:23 PM   #8
Msports33
Msports33's Avatar
no problems with lowering, it took the oversteer problems away. Valving is great with these dampers. We ran per T2 Rules max front camber 2.5 and rear 1.2 or so. Per track we ran Z-28 or 1LE bars.
Old 01-24-2019, 07:50 PM   #9
Msports33
Msports33's Avatar
bump new winter price
Old 02-01-2019, 12:03 PM   #10
DavidtheM
DavidtheM's Avatar
Drives: 2014 Camaro 2SS 1LE
I’m interested but I can’t find any info out there on the reliability/effectiveness on what you did to lower the shocks/struts
DavidtheM is offline   Reply With Quote
