01-21-2019, 01:45 PM | #1 |
Drives: 2014 Red Camaro Join Date: Jan 2019
Best 2014 V6 exhaust
What is the best sounding exhaust for a 2014 V6 Camaro? The loudest exhaust without a droning/rice burner sound? I’ve done a lot of research and read a lot of good reviews on the Flowmaster. Any opinions would be appreciated!
01-21-2019, 01:53 PM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Very much a loaded question. Opinions will vary.
Personally, cat deletes, Magnaflow 11386 X muffler in place of stock H, and muffler delete. Loud. Sounds good. Flowmasters to me always sound awful.
01-21-2019, 02:21 PM | #3 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
I always liked the solo high-flow into their cat-back sound. When I had my LFX, I was going to do that set up.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
01-23-2019, 07:15 AM | #4 |
Drives: 2014 Black LS Join Date: Aug 2018
I have ARH Catless Downpipes, Magnaflow resonated x pipe, along with magnaflow mufflers installed in the back. That in combination with the Cold Air Inductions Cai I have installed, it sounds really good. I will say it’s a little quieter than I had originally hoped for from the start but I recommend the setup. However I was wondering if anyone has this set up minus the resonated x pipe. I’m thinking of removing it but don’t want to make a mistake. I want crackles and pops and right now it’s almost nonexistent. I might decide after I upgrade to the overkill throttle body and tune. Hope this helps and hope someone sees this and can help as well.
01-23-2019, 01:41 PM | #5 | |
Drives: 2015 Z/22 Join Date: Aug 2015
01-24-2019, 06:19 PM | #6 | |
01-24-2019, 09:40 PM | #7 |
Magnaflow resonated x with muffler delete is a killer option.
01-25-2019, 05:55 AM | #8 | |
03-13-2019, 04:16 PM | #9 |
Drives: Chevrolet Camaro 1LT Join Date: Mar 2019
2011 Camaro V6 intake and exhaust
I just got a 2011 V6 Camaro and I'm looking for the best cold air intake for it. I researched a lot but i don't know which one to pick. You guys have any recommendations? I also want an exhaust which sounds mean and aggressive with cracks and pops.
