11-13-2014, 10:56 AM | #1 |
Drives: 2013 2SS/RS convertable Join Date: Aug 2014
Suggestions to get a Vert into 11's?
Current mods in sig. according to the door well sticker she weighs 4970 lbs...
I'll have about $5-$6k to throw at her in the next couple months, work will be done at Lashway (they did my headers + tune already and I like the work they do, and customer service is top notch) Already have 3.91 gears (not yet installed). Thinking Cam, UD pulley, and Torque Converter should fit that budget, but will they get me there? unofficially Doing 12.6 now (using Torque Pro app with bluetooth OBDII on a closed private road)
2013 2SS/RS Vert
Mods list to long to fit in sig now lol Check build thread http://www.camaro5.com/forums/showthread.php?t=377507 |
11-13-2014, 12:03 PM | #2 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Supposedly 300 lbs heavier, but 49xx would surprise me.
Local guy (maybe Steve will chime in) has H/C/exhaust/3600/3.70/skinny/DRs and I think his current best is 11.92.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
11-13-2014, 12:58 PM | #3 |
Drives: 2010 2ss Join Date: Dec 2012
The door sticker is GVWR meaning total weight vehicle can hold.
2010 l99 summit white w/inferno orange stripes and interior. Texas Speed longtubes, halltech cold air intake,v-max ported throttle body, MSD wires, NGK plugs, Spintech catback with x-pipe, GPI SS1 VVT camshaft.
11-13-2014, 12:58 PM | #4 |
Drives: 2011camaro SS Join Date: Nov 2012
You can get to 11's a number of ways! Cam and bolt Ons, good converter and wheels and tires! Or find a used blower.
11-13-2014, 01:42 PM | #5 |
I had a stage 3 tooley cam, pfadt tri y headers, adm airbox, 3200 stall, 3.45 gears and magnaflow exhaust and had my 11 convertable running 11.80 on street tires with a 1.79 60 ft on stock goodyears.
11-13-2014, 03:46 PM | #6 | |
Haven't been able to find official weight on the verts anywhere. Thanks for the input guys.
2013 2SS/RS Vert
11-13-2014, 05:05 PM | #7 |
Writer
I'm guessing 4500 with 200 lb driver.
PROJECT HEAVY CHEVY
11-13-2014, 05:16 PM | #8 |
Drives: 1969 Z/28 Join Date: Nov 2008
I think you're definitely going to need a cam with all the other mods you are planning...
11-13-2014, 07:37 PM | #9 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
I have what you need , maggie 2300 with about 4000 miles, my wifes car..Switching to new heartbeat...Convertible with 22s runs 11.7x leaving soft.
11-14-2014, 09:27 PM | #10 |
Drives: 2011 camaro 2ss convertible Join Date: Jan 2014
curb weight is 4100 on verts,i have a 2011 vert and we are at a slight disadvantage of appx 300-350 pounds to the coupe.i have heads and cam and long tubes and cold air intake and had 2800 stall and ran 12.10 .changed to a 3.70 gear and 3600 stall and was able to cut 11.90 on a conservative tune.with a little more aggressive tune and 3.91 and intake manifold and 25% ud pulley should be able to run low to mid 11's.take your time read what everyone else has done combo wise to see what works best.
