Emblempros
Old 10-03-2019, 07:36 PM   #1
judkins75
Silver Shark
Drives: 2014 Camaro 2ss/rs npp 6sp man-tran
3.91 gear talk
My dealer quoted me a price on gears. $429 for gear kit and $693/6.3 hours install. I think I'm going to pull the trigger this winter. I've read a lot of post on 3.91, but does anyone have more up too date info and ride info on using 3.91 gears on a daily driver...
Silver Shark
judkins75 is online now   Reply With Quote
Old 10-03-2019, 08:16 PM   #2
IWANTA(ss)
IWANTA(ss)'s Avatar
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14
I’m in the middle of a gear swap from 3.91 to 4.11. I do have a big cam, but I think the most popular answer is 4.11 manual cars and 3.91 for the L99. But search for acammer on here and read his great write ups and you’ll find some good info. If you can swing it look into the true-trac, lpw cover and some bushings for the diff since your opening it open anyway.
02 Stepside Silverado
05 ZX-10
13 1LE
14 Nightrod Special
IWANTA(ss) is offline   Reply With Quote
Old 10-03-2019, 09:02 PM   #3
lemontwist
lemontwist's Avatar
Drives: 2011 2SS/RS M6
there is a guy on here selling 391's from his 1le for 1k i would just buy that and put it in.
lemontwist is offline   Reply With Quote
Old 10-03-2019, 09:35 PM   #4
KerseySS
Joey
KerseySS's Avatar
Drives: 2011 Camaro 2SS/RS L99 Cyber Grey
It’s a lot more fun to drive with the 3.91 but you will lose about 1.5 mpg
2011 Cyber Grey L99 SS/RS- 3.91 Gear
MRR 228 Wheels-Hurst shifter/base plate
LT Headers no CATS-Magnaflow 16582 Axle Back
RoboFab intake-Dyno Steve tune
ZL1 Rocker Panels-SLP Splitter
Lowered on Phastek springs
Pray Performance ported TB
KerseySS is offline   Reply With Quote
Old 10-03-2019, 10:08 PM   #5
TheFlyingBananaSS
Camaro Superhero
TheFlyingBananaSS's Avatar
Drives: 2013 Camaro 2SS & 2015 LaCrosse
Besides a tune, it's the best bang for buck mod you can do. You car will wake up and you will have fun driving it again.
TheFlyingBananaSS is offline   Reply With Quote
Old 10-03-2019, 10:28 PM   #6
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
3.91 gear is a great upgrade. You will lose a few mpgs but the car will feel lighter and accelerate quicker. If you want to go all out, go straight to 4.11. I should have, so when I rebuild the diff in my garage it will get a 4.11 gear.
Forged 378, E85, milled GMPP ported heads, Night Fury, Vmax TB, GPI rod mod manifold,Improved racing,Melling,ATI, DSE, DW, Smith Brothers, McLeod twin RXT, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Vararam OTR intake,Tick,Elite CC,Kooks LT/HFC,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane radius arm inserts,BMR steering rack bushing,Goodridge brake lines,Ridetech HQ level 2 coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017,Continental Extreme Contact
Black_SS10 is offline   Reply With Quote
Old 10-04-2019, 09:46 AM   #7
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
Is the car a manual or automatic? If it's a manual, you should consider 4.10s or 4.11s. acammer convinced me to do the same and I am really glad I listened. An even lower ratio would be better, but in my case, the cost was prohibitive.
CAI Cold Air Intake; Comp Cams LSR Series; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; AEM Wideband; N2MB WOT Box;
Tuned by Throttle Works 467whp 419 wtq
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 10-04-2019, 02:03 PM   #8
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
My car is a LS3/M6
TSP stage 3 cam
I daily it with 3.91s
4.11 would be better for the strip but the 3.91 is a good middle ground for my setup
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 10-04-2019, 02:59 PM   #9
GK_2012_SS
GK_2012_SS's Avatar
Drives: 2012 Camaro LS3 2SS
Everyone seems to love the 3.91. My question: is there any concerns over the stock SS differential and transmission? My understanding is that the 1LE (which includes the 3.91) has a stronger differential and a different version of the TR6060. My car is a manual SS (not 1LE), I would hate to do this mod then start breaking parts. BTW - I don't race, just street.
Z/28 Cold Air Intake; ARH 1 7/8 Long Tube Headers, High-flow Cats, X-Pipe; Borla S-Type; 160 Deg. Thermostat; Tune
GK_2012_SS is online now   Reply With Quote
Old 10-04-2019, 04:38 PM   #10
anthony.martinez
Drives: 2010
Yes the trade off is miles per gallon for Smiles per gallon!!! It is a great gear for cruising the highway too.
anthony.martinez is offline   Reply With Quote
Old 10-04-2019, 05:08 PM   #11
Black_SS10
SomeguyK
Black_SS10's Avatar
The diffs are the same just different gearing. The trans are the same, different gear sets because of the 3.91 gearing. The SS tr6060 will have a very short 1st gear with 1LE 3.91 vs the SS 3.45.
This is a good read about adding 3.91 to a manual SS.
https://www.camaro5.com/forums/showthread.php?t=284343
Old 10-04-2019, 09:20 PM   #12
acammer
Back in the game
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
If you have a M6 car that doesn't have a power adder then anything less than a 4.10 gear is leaving performance on the table. There are really no significant drawbacks to a 4.10. You will gain a couple hundred RPMs at cruising speed in top gear, 70mph is right around 2000rpm - which is a still completely reasonable. I lost 1.5mpg at 70mph. It was no different in mixed/city driving, that all depends on the driver.
From a drag race perspective, you definitely want the 4.10. These are heavy cars, and they need all the help they can get to get moving. Additionally, with the 1:1 4th gear you need to get the RPMs up.
Like Zlathim said, if we could get more gear in the rear end, I would have a 4.56 back there. Zane and I run 26" tires (stock is 28.66") at the track specifically to increase the final drive ratio. It makes the car easier to launch, and helps down the back half of the track, getting the car back up into the power sooner after you make the 3-4 shift.
2011 2SS SGM - CAI, PTB, Rod-Mod and ported intake, GPI SS3 cam, AR LTs 1.875", X-pipe, high flow cats, cutouts behind the axle. 25% UPD, 169*F stat, EE catch can, Ideal Garage clutch master, seperate reservoir, Tick-Shift billet throwout support, Yukon 4.10 gears, TruTrac Differential, LPW Differential Cover, BMR Pro diff bushings, Pegasus Solid rear sub-frame bushings. 497rwhp. 11.67@119 2+ton raceweight.
acammer is offline   Reply With Quote
Old 10-04-2019, 09:31 PM   #13
lemontwist
lemontwist's Avatar
boom 1200
used 3.91
https://www.hawksmotorsports.com/201...-3-91-used-gm/
Old 10-05-2019, 12:47 AM   #14
mbesman
Great White
mbesman's Avatar
Drives: 2015 Camaro 2SS
That's no too bad of a deal and you get a full warranty with the dealer install. I had mine installed at dealer. They did not tune the car though (adjust for speedometer) I have a Diablo tune that I was able to use to adjust the speedo so that didn't concern me. If you don't own one, you will need to get it tuned to adjust for the gears at a minimum.
mbesman is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
