01-21-2011, 09:03 AM | #1 |
Drives: Corvette Join Date: Jan 2011
GM has a TSB for the broken output shaft for M10
This bulletin just came out on Jan 11, 2011. It just states to call GM tech assistance center. I'll keep you guys posted.
#PIP4666E: Vehicle Not Moving In Any Gear - (Jan 11, 2011) Subject:Vehicle Will Not Move In Any Gear Models:2010 Chevrolet Camaro Equipped With The Tremec 6-Speed Manual Transmission RPO M10 This PI was superseded to update the keywords. Please discard PIP4666D. The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI. Condition/Concern: Customer may comment that the vehicle will not move in any gear. Technicians may find the transmission output shaft broken. Recommendation/Instructions: If a vehicle comes into the dealer with the concern described above please contact the General Motors Technical Assistance Center at xxx-xxx-xxxx (USA) or xxx-xxx-xxxx (Canada), TAC will supply further instructions at that time. Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
01-21-2011, 09:17 AM | #2 |
BAMF SS
WIN!
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
01-21-2011, 09:49 AM | #3 |
wtf lil late imo
85 Buick TType - 5.3l GT4202r 10.86 at 126
01-21-2011, 09:59 AM | #4 |
www.Camaro5store.com
A little late....lmao.
Hey...they are getting it done. Happy to see GM stand by their products and do what's right! GOOD JOB, GM! |
01-21-2011, 10:47 AM | #5 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Version E, it's been out for a long time.
I'd be more impressed if it stated the cause, and to repair the customer's car without hassle or blame on mods/tuning. |
01-21-2011, 11:21 AM | #6 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
.........long time coming but better late than never. Now let's all go out and test the Lauch Control!
01-23-2011, 09:28 AM | #7 |
Drives: 2013 Dodge Charge R/T Plus AWD Join Date: Jul 2009
i have done the launch control a few times before I put her away for the winter. Looks like I might have a GOOD OUTPUT shaft.
I can't wait until spring so I can get her out of the garage and start driving her again. When I open the garage door and she see's all that snow out there, she flashes her lights, like she wants to go out and play in it. But i won't let her.........Soon....Soon...lol |
01-31-2011, 08:15 PM | #8 |
Indie Zombie Film King
I run mine out in the snow, its fun stuff, plus I only have an LS M6 V6, but after all the snow playtime I always take her to the car wash and give her a nice long 10-15 bath especially concentrating on the undercarriage
I am also an INDIE FILMMAKER |
01-31-2011, 08:20 PM | #9 |
Drives: 2010 2SS/RS IBM Black Polished Join Date: Feb 2009
I would bet when the technician calls in to get instructions it includes inspecton for power adders thereby voiding warranty....just sayin.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
01-31-2011, 08:22 PM | #10 |
ZEUSS
Any idea of the VIN# range?
01-31-2011, 08:51 PM | #11 | |
BAMF SS
it covers ALL vin's. To break it down barney style, if you have said problem, GM will fix it. The question is, after how many transmissions will GM say enough.... I have a feeling that I'm going to find out... lol.
01-31-2011, 08:54 PM | #12 |
Drives: 2010 Camaro SS/RS 6spd Join Date: Sep 2009
Similar Threads | ||||
Tally of broken output shaft VIN's | ssmike | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 165 | 01-11-2013 10:07 PM |
Camaro team's response to concern about Transmission Output Shaft Failure | Mr. Wyndham | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 389 | 07-09-2011 11:09 AM |
GM has a TSB for the broken output shaft for M10 | Rick@RKT56 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 7 | 01-21-2011 02:07 PM |
M6 output shaft, ticking time bomb? | ssmike | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 5 | 12-14-2010 07:18 PM |
