09-17-2017, 06:47 AM | #1 |
Drives: Camaro 2SS 2013 (EU Version) Join Date: Jun 2012
Driveshaft tunnel brace
Hi guys
I have a little problem with my car. My American Racing long tube headers is touching the stock black Driveshaft tunnel brace and is making noise when you drive. I need a new driveshaft tunnel brace in order to have more space between this and the long tube headers. Do you have some ideas ? I'm living in Italy, a lot of wesite does't ship to me or the cost is like 150 (only shipping) I saw this: https://www.carid.com/umi-performanc...pn-2500-r.html Is gonna work fine?? If you have different ideas let me know ! Thanks |
09-17-2017, 07:19 AM | #2 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
The one from BMR is only $59.95US. I'm looking at one, but I don't know if it'll give me extra clearance or not. Mine was rubbing, but we were able to tighten it and adjust the way it hung and now it doesn't rub anymore. I still occasionally hear it clang off the brace when going over bumps, but I looked the other day and it's still not in contact when parked.
09-17-2017, 07:23 AM | #3 | |
I saw the BMR. The problem is i didn't find any company that offer international shipping at reasonable price. I found only two websites and the price is 150for shipping + 60for BMR... I Was looking to carid because the shipping cost is 55 |
09-17-2017, 07:33 AM | #4 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
Can you show a picture of where it's rubbing?
09-17-2017, 07:42 AM | #5 |
don't know if you can see well. This is the right part (the part that touch)
09-17-2017, 08:18 AM | #6 |
old school chevy rodder
Since it is to stiffen the area you could remove the tunnel brace and modify it for cheap at a welders shop to not touch...no shipping required or fashion a new one , I see you have spaced it out with multiple washers......
09-17-2017, 08:20 AM | #7 |
Drives: 69 SS Camaro 2019 Corvette GS Vert. Join Date: Jan 2017
Unless you are racing the car, an easy fix is to obtain four Grade 8 bolts that are a 1/4 inch longer and add a 1/4 inch spacer between the cross brace and the unibody. That will solve your noise problem.
There is a fine line between hobby and obsession and I think I crossed it!!
09-17-2017, 08:24 AM | #8 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
easy fix, get sumthin like 'dis...steel bolt spacer and longer bolts!
http://www.homedepot.com/p/The-Hillm...FeW2swodh9gIrA (above just a description) Good luck!
09-17-2017, 08:28 AM | #9 | ||
Does it work by adding spacers only? Will I have future problems with this solution? EDIT: What happens if i remove the stock black brace and I put nothing down? Last edited by teobilly; 09-17-2017 at 09:04 AM. |
09-17-2017, 08:40 AM | #10 |
Svt lol
Ok I wasn't for sure exactly what you were talking about. Like stated above go buy a couple longer bolts and put some spacers in problem solved OR..........if you're in the market to spend some money look into a hotckis subframe brace setup that would really make a difference if you race your car.
09-17-2017, 09:14 AM | #11 |
Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
I'd try the BMR Brace and see if you have the same issue. It can be found for $45-50 US if you look hard enough. If it still rubs, look into spacing it one washer at a time until you get the clearance you need.
The stock tunnel brace is trash, so thats why I recommend going with the BMR and modifying that to work if needed.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
09-17-2017, 02:13 PM | #12 |
Drives: 2018 Camaro ZL1 1LE Join Date: Apr 2015
I wonder why yours is rubbing I'm running the same setup with no issues
09-17-2017, 02:21 PM | #13 |
Drives: 2012 SS/RS MN6 Join Date: Mar 2016
I'd try to space it first. I ended up picking up a BMR one from Summit and fixed the issue.
09-17-2017, 07:15 PM | #14 |
Mine has been in the recycle bin since I bought my car almost.
