Old 04-24-2018, 11:46 AM   #1
aquariuss
Drives: 2015 Camaro SS
Question Coolant alternatives to GM made one ?
Hi guys,
Am looking at coolant alternatives to GM made one Dex-Cool ? I'm from Europe and to make matters worse from a country that has only exDaewoo Chevy dealers who turn pale at the sight of a Camaro.
I damaged my radiator and sprung a leak so after replacing all the parts i would like to do a flush with distilled water and fill with a correct coolant.
The problem is i can't source Dexcool within reasonable delivery costs, what other brands and types of coolants would you recommend ?
GM/Ac Delco stuff is out of the question i would have to ship it from the US or the UK.
Thanks !
aquariuss is offline   Reply With Quote
Old 04-26-2018, 05:00 PM   #2
Synner
Drives: cars
If you completely flush the system you can convert to standard ethelyne glycol 50/50 mix. It's available everywhere.
Old 04-30-2018, 03:06 PM   #3
Russell James
Russell James's Avatar
There are many brands of Dexcool.
I wouldn't use anything other than Dexcool in a system that started life with Dexcool. The two types are incompatible.
I can't imagine there are zero brands of Dexcool in whatever country you are in. All the major antifreeze companies have a version of Dexcool. Valvoline has a version called Zerex, their website says it's available in over 100 countries.
Old 04-30-2018, 03:33 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
Buy dexcool concentrate and mix with distilled water. May be able to have less shipped from US.
-Don
747 RWHP 794 RWTQ
Old 05-10-2018, 12:47 AM   #5
rdanzel
Drives: 2010
Have you tried looking for an orange silicate-free coolant that meets GM specifications for Dexcool? Maybe some local auto parts supply has it.
rdanzel is offline   Reply With Quote
