#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Audio, Video, Bluetooth, Nav, Radar, Electronics
Old 02-21-2024, 09:21 AM   #1
Juniorv130
Juniorv130's Avatar
Drives: 2022 1LE
Speaker tap 2023 1SS vert.
Hi!
I have a Kicker HS8 powered sub i ran in another car that was totally satisfactory for my needs. I need to tap into the rear speakers on my 1SS convertible. I know that i can pull the sail panels in the rear for speaker access but need to tap there and run to the trunk for the amp.
The amp needs speaker input from both sides, a hot, and ground. Obviously hot and ground are in the trunk. I was looking but of course the top doesnt want to stay in the half open position. Anyone have any insight as to where to tap in or where the best place to run wires is?
Or , can i disconnect the battery while the top is half open so it stays there?
thanks!
2012 THR45 SS - CFM - SOLD
2015 2SS 1LE - White - SOLD
2002 Corvette coupe - 6M - Millenium yellow - SOLD
2010 2SS RS - RJM - 6M - SOLD
Juniorv130 is offline   Reply With Quote
Old 02-27-2024, 08:23 PM   #2
Plasar
Drives: 2017 ZL1 Vert M6
This MIGHT help with your question about keeping the top open:
https://www.camaro6.com/forums/showthread.php?t=480519
Plasar is offline   Reply With Quote
Old 02-29-2024, 08:08 AM   #3
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
You don't want to tap into the rear speaker signals for your sub: they aren't full frequency range. You want to tap into the front speaker signal.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 02-29-2024, 04:47 PM   #4
Plasar
Bose or non-Bose?
https://lljcustoms.com/products/2019...fier-t-harness
https://t-harness.com/products/2013-...-t-harness-r2g
Old 03-01-2024, 02:29 PM   #5
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
THIS, and tap both front left and front right.
If it's non-Bose, you can access the speaker wires at the passenger side dash or at the dash speaker location. If it's Bose (meaning you have the technology package), then you'll want to intercept at the factory sub output.
Assuming it's non-Bose, I have all of the 1SS audio schematics. Attached are with and without active noise cancelling, non-Bose.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair.
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22
Daily Driver mileage update: 22k mi. @ April 2024
New Engine @ 22,600
Build Log: https://www.camaro6.com/forums/showt...6#post11353116
keep_hope_alive is offline   Reply With Quote
Old 03-04-2024, 09:37 PM   #6
Plasar
Dean and Fernando at Five Star Car Audio agree with Msquared and Keep_hope_alive.
https://youtu.be/xqsvpggwfyE?si=LJ84yocRNzKxctpr
Old 03-05-2024, 05:59 AM   #7
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
Don't forget to cut your active noise canceling wire!
Booher is offline   Reply With Quote
Old 03-05-2024, 08:11 AM   #8
keep_hope_alive
Electrical Engineer
Attached are a collection of ANC schematics, pin-out diagrams, and the system description.
Disconnecting the microphones is the easiest solution that doesn't require cutting wiring, and there are two mics. How the system integrates depends on the trim level/audio system you have.
New Engine @ 22,600
Old 03-05-2024, 07:03 PM   #9
Msquared
Msquared's Avatar
Everything they said is correct, and it's pretty damn annoying that one of eight speaker wire outputs is on the other connector to the radio module. However, that is one of the rear wires. I had Gen5DIY build me a breakout harness for just the other connector that has all the front speaker signals on it. That is better IMO than cutting or tapping the factory wires, and it's actually easy to install because you don't have to drop the module to plug these in (at least on 2019+ models). And of course it's fully reversible.
Matt Miller
2020 SS 1LE
Old 03-06-2024, 08:40 AM   #10
keep_hope_alive
Electrical Engineer
I also intercepted my wiring with a breakout harness:
New Engine @ 22,600
Old 04-13-2024, 10:43 AM   #11
Juniorv130
Juniorv130's Avatar
Drives: 2022 1LE
Thanks all! I am digging back into the project.
Old 04-13-2024, 10:48 AM   #12
Juniorv130
Juniorv130's Avatar
Drives: 2022 1LE
does anyone have any insight about how to get into the trunk though....the convertible top in the way is still a thing.
