04-07-2015, 08:28 PM | #1 |
Drives: 2012 chevy camaro ls Join Date: Jan 2015
smaller pulley
so I have brother and he also have a vortech v3 on his coyote and he just switched to a smaller pulley he said he will give me his old one for free. its a 3.6 ive heard the one for the ipf kit is 3.8. do you think the 3.6 will fit there both v3s and what can I expect from a smaller pulley. gains in boost and hp? what else? looking to get some insight as this is something I don't know a lot about.
04-07-2015, 09:15 PM | #2 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
If it is a 6-rib and it is centered it will work, but the pulley's from Vortech have an offset so 1/4" has to be cut from the big end to get it to center on the IPF bracket. 1 step down is about 1-2 PSI gain, I run a 3.48" pulley and get 11-13 PSI, depending on the air.
04-07-2015, 09:30 PM | #3 |
would I need a new belt?
04-07-2015, 09:34 PM | #4 |
For a 3.48" yes, the IPF belt is pushing the limits, might be safe with a 3.6" pulley.
04-07-2015, 09:35 PM | #5 |
and when you are talking about 1/4 being cut from the big end. like cutting the bracket really not sure what you mean. sorry for the noob question
04-07-2015, 10:00 PM | #6 |
The pulley itself, you will see it when you do it, hard to explain.
04-07-2015, 10:09 PM | #7 |
oh ok so its just alteration to the pulley, so if for some reason if I wanted to go back I could right?
04-07-2015, 10:28 PM | #8 |
also did you have to alter you pulley as well to make it work?
04-08-2015, 08:14 AM | #9 |
04-08-2015, 11:23 PM | #10 |
thanks thread did answer some questions unfortunately it created some more lol. really considering a 3.48 pulley now
