04-09-2012, 03:14 PM | #1 |
Headers or Hi flo Cats
I just purchased a 2012 Camaro SS LS99 and trying to fnd out if I should go with Hi flo Cats or Headers..????
04-09-2012, 03:25 PM | #2 |
Drives: 2010 IBM Camaro 1LT / RS Join Date: Jun 2010
headers will usually give you more power, if that's what you're looking for.
1944 Willys Jeep
2010 Camaro RS IMB w/ Sound System upgrade + Sunroof, Chrome gills |
04-09-2012, 03:32 PM | #3 |
Well Headers With or without High-Flow cats will generate the most gains but will require a tune and void your warranty. If you get High-Flow Cats (also referred to as a mid-pipe) you will get decent gains and usually don't need to tune. Although sometimes you still do.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
04-09-2012, 03:32 PM | #4 |
HT5 COTW 9/3/2012
If your going to upgrade later to FI then go with headers and off road pipes and if not headers and hi flow cats will do fine,but you still need to get a tune with he headers.
04-09-2012, 03:39 PM | #5 |
Whats FI???
04-09-2012, 03:42 PM | #6 |
Treasure Coast Camaro 5
Forced Induction.
04-09-2012, 03:49 PM | #7 |
Both
Mods: "Cam Only"
04-09-2012, 03:50 PM | #8 |
Get Both
04-09-2012, 03:54 PM | #9 |
Drives: 2020 Summit White LT1 M6 Join Date: Sep 2011
I have both and my camaro runs and sounds great!
04-09-2012, 03:59 PM | #10 |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
Since you just got your car you may want to keep a warranty for a while. Check into Solo cats. You can get up to 20 HP gain with no tune and no CEL errors with an intake included. There's a guy I met with stock tuen, a CAI, Solo cats, and axle-back exhaust that made around 388 RWHP while I made 366 with only a CAI and cat-back (we dynoed the same day, same dyno). My car at the time only had 850 miles and at 2300 miles with the same setup I made more HP after the engine loosened up, but no where near 388. So the gains can be made without headers.
04-09-2012, 04:23 PM | #11 |
Is there a LTB header that fits with hi flo cats..??
04-09-2012, 04:29 PM | #12 |
All can. Just depends on your wallet.
04-09-2012, 05:10 PM | #13 |
If you want LT header and cats, then plan on a tune at some point soon. As stated above, you can buy complete set of matching headers and cats that fit together and attach to your stock exhaust, or aftermarket cat-back. Best to decide what direction you want to go and talk with any one of the vendors on here for what works with your setup. There's a ton of good header manufacturers and lots of opinions of what are best. Of the top ones, IMO they are pretty close and it will boil down to price.
First decide what you want to accomplish: cats only, LTs and cats, which exhaust, stock or aftermarket. What are your plans down the road for additional mods. Then go shopping.
04-09-2012, 05:19 PM | #14 |
Thanks for all the info guys!!
Similar Threads | ||||
Check your cats... | shaner74 | Forced Induction - V8 | 628 | 11-15-2016 04:20 PM |
Those with Headers. Cats or No Cats? | Rogan | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 46 | 10-20-2011 08:58 AM |
Kooks 1 7/8 silver coated headers with hi flo cats!! | ilovehooters1385 | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 11 | 09-03-2011 02:33 PM |
Dynatech Long Tube Headers + Hi Flow Cats On Sale @ 2 EDGE PERFORMANCE | MRGOODWRENCH3 | V8 Bolt-Ons & Tunes | 4 | 08-14-2011 10:32 AM |
Borla headers install w/ stock cats and borla "s" type exhaust | Jojo | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 11-20-2010 06:26 PM |
