10-03-2014, 03:56 PM | #1 |
Drives: Red 2SS/RS M6 Join Date: Apr 2010
ACS upper rear quarter vents
When i first saw them on the new stingray i loved them ACS made them and i said time to break out the air saws, files and die grinders
Pretty straight forward, lay the template, cut a hole and install vent . ok, ok its a little more than that but I'm happy with the out come . i first set in the passenger side and the rear of the vent was not sitting completly flush, i have to remove it, clean it and reinstall, but the 2nd time was a charm:headband:, the driver side didn't sit as flush in the rear so i had to file off a little at a time until it was seated good it took some time as i added lights, also you want to get the holes cut, make sure everything fits well, then i would paint the vents and then next day install them. overall i very happy with the outcome. pictures on 2nd post Last edited by overhaulengines; 10-04-2014 at 04:04 PM. |
10-03-2014, 03:57 PM | #2 |
pic's coming in a bit
10-03-2014, 09:29 PM | #3 |
Turbine Maker
Drives: 2012 Camaro 2LT-RS "LFX"V6 Join Date: May 2012
Lupe looks great...
10-03-2014, 09:40 PM | #4 |
'It's an experiment'
Does look great -- but still think the price is steep considering what I got the Hex Vents for -- painted.
May have to build these myself -- did fiberglass work for 8 years so -- who knows! |
10-04-2014, 09:10 AM | #5 |
Lupe, what type of adhesive do you use for that? Almost looks like JB Weld ;o)
Still wanted to say that is a very nice job! -Don |
10-04-2014, 09:25 AM | #6 |
10-04-2014, 09:57 AM | #7 |
thanks! I used flox with my layups so I figured it was some 2 part epoxy system. you guys do really nice work! I think I'll see if I can create molds and see how that goes.
Do you keep the templates? How big are the openings you cut out (if you're allowed to divulge that info)? -Don |
10-04-2014, 09:58 AM | #8 |
I have some left over carbon fiber I want to try this on... ;o)
10-04-2014, 10:06 AM | #9 |
Whipped
what happens when your LED's go out? I don't see any option on how to replace them. Also, besides looks, Does this do anything? I know on the C7 they are functional.
10-04-2014, 10:49 AM | #10 | |
if my lights go out i will either remove the vent ( i did once already cuz after it dried i realized it wasn't seated on the rear part or just cut the wire to the other side my oldest leds are over 4 years old, they all still work hopefully they will continue to work for years to come. i drive it 2-3 times a month, no rain, so they should last lupe |
10-04-2014, 03:42 PM | #11 |
Drives: Camaro SS/RS inferno red interior Join Date: Mar 2012
ACS said it IS FUNCTIONAL on there website
Quote: "Rear Quarter Upper ports are functional inlet ports designed to inhale fresh air and redirect to the rear braking system for enhanced cooling. Air inlet direct fresh air directly to the rear brakes via a series of cooling hoses and air deflectors to be installed on the rear quarter panel." -end quote
SoFlo Muscle Car Group
Miami/Broward |
10-04-2014, 09:22 PM | #12 | |
Drives: 2014 Camaro 2SS/RS 1LE Join Date: Dec 2013
Something tells me that 3/4" hole in the bottom of the vent is going to do VERY little in terms of venting anything. As long as you put these things on for purely aesthetic purposes then I guess go for it - but I'm not a big fan of taking chunks out of panels for aesthetics unless it's bumping up performance of some kind. Why not just use some 3M double sided foam tape and just stick the trim piece on? Same difference IMO... Sent from my iPhone using Tapatalk |
10-04-2014, 10:43 PM | #13 | |
For $1000 (kit, painted, etc.), I can get new performance tires (or close to that price since I have ZL1 wheels), upgrade cam, or a host of other items that would actually 'help' the car's performance vs 'looks'. I think I'll wait and see if these come down. The hex vents help with cooling so that made sense to me... Whipple81 -- thanks for the insight... -Don |
10-04-2014, 10:55 PM | #14 |
some are into horsepower, some are not. some are into looks and some are not. some are on a budget some are not. do as you please, i have a little of both
since i have the tires i want, the cam i want, the suspension i want, and all the cosmetics i want.....not really i want more lupe |
