11-04-2013, 12:49 PM | #1 |
Too Many Great Choices
Drives: Grand Sport/Z07 Join Date: Jun 2009
Your Recipe for Turning a 1LE Into a Z/28 Performer
Being cost efficient, what's your ideas for taking a 1LE to Z/28 performing levels?
11-04-2013, 12:57 PM | #2 |
Sellin Chevy's since '06
MULTIMATIC strut assemblies and 305/19s all around.
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0 SOLD! '18 ZL1 Mosiac Blk SOLD!'16 SS Sedan-Forgestars/ARH/rotofab TRADED!2014 SS Sedan SOLD! 2013 Blue Ray1SS/1LE 1of20. TRADED! 2012 White 1SS/RS |
11-04-2013, 01:05 PM | #3 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
Heads, cam, intake, exhaust with suspension upgrades.
11-04-2013, 02:50 PM | #4 |
Casey Woodside
Drives: a very fun car Join Date: Jun 2010
305/19/30 tires pedders supercar coil over pedders hd bushings all of them
Heads and cam or 416 stroker
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w |
11-04-2013, 04:06 PM | #5 | |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
n xr1/xr3 pads
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
11-04-2013, 04:25 PM | #6 |
RIP - Convertible SS
Drives: '13 Mustang Boss 302 - RED Join Date: Apr 2011
....and a weight dump.
11-04-2013, 04:27 PM | #7 |
Drives: cars Join Date: May 2011
And find 200-300lbs to cut.
11-04-2013, 04:41 PM | #8 |
Casey Woodside
Yes good call forgot about the big ass breaks
11-04-2013, 06:08 PM | #9 |
Drives: '10 CGM 2SS/RS 6M Join Date: Oct 2009
How ever you slice the pie, even including buying a crate LS7 and selling the pull out motor you'll be a heck of a lot cheaper building up a really close comparo to the Z/28 and upgrade brakes and tires, suspension to what the dealers are going to command for the real thing
11-04-2013, 06:28 PM | #10 |
Drives: 2023 ZLE Join Date: Jun 2009
Pedders Supercar c/o'sL. Mild cam and headers. 19's squared up with some sticky rubber. That would be pretty stout.
11-04-2013, 09:52 PM | #11 | |
Drives: Camaro's, always have, always will. Join Date: Oct 2010
11-05-2013, 06:23 AM | #12 | |
Here would be my list for a low cost Z/28b (for bargain): Start with a bare white 1SS with NPP and Recaros only. Really this is still a very well equipped car. (But I love tunes so I also would add BA) Every other option adds weight and is not in the spirit of the Z/28.
I would wager with equal drivers the Z/28b would be able to keep a stock Z/28 in sight on any track. At least for a while. And finally add a mild cam and real track tires to get even with the Z/28. If you can DIY the cam is not that expensive.
"Democracy Dies in Darkness" Last edited by Fraxum; 11-06-2013 at 05:02 PM. |
11-05-2013, 12:02 PM | #13 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
You can currently build a 1SS/1LE with Recaros for just under $40k - and in keeping with the Z/28's character this is pretty much the barest-bones 1LE you can build. If we then assume $70k to be the going OTD price for a "real" Z/28, that leaves you with whatever fraction of $30k you care to consider represents cost effectiveness. Don't overlook the possibility of selling off some or all of the parts you replace, which in particular would take some of the financial sting out of an LS-7 swap.
So how far does anybody think that, say, $15k will get them? I have to admit that I'm looking at this as a DIY effort. But other than getting all the electronics to play nice with each other if you went the LS-7 route I don't see anything in the physical part of making the modifications being all that difficult. Tires - your choice, but at least 305-wide Wheels - not less than 11's with 305's, or 11.5's with 315's. Half an inch more if at all possible. 15" rotors will need 19's, 14" rotors only 18's. Suspension - probably coilovers with at least single-adjustable damping and infinitely adjustable sta-bars (such bars are not available commercially for this car that I know of, but this can be done at the DIY-level). Firmer bushings and/or spherical-ended suspension links. Big brake kit, though right about here you'd have to decide whether the car was going to be almost exclusively a track toy or not. Even entry-level track pads can be a lot harder on rotors than performance street pads. Norm |
11-05-2013, 01:05 PM | #14 |
Drives: Unicycle Join Date: Oct 2009
I wonder how much you could realistically get for take off LS3 long block? Assuming brand new car off the lot.
