11-28-2018, 02:13 PM | #1 |
Drives: Camaro Join Date: Oct 2018
KW V3 rear coilovers
Barely used, less than 250 miles, rear KW V3 coilovers with no springs. No issues with them at all and would install today if I needed to.
$450 shipped. Last edited by Roader; 12-26-2018 at 11:30 AM. |
12-21-2018, 08:13 PM | #2 |
what was wrong with these when you had them. I have pedders and need just rear coilovers only. how do yours adjust for the different settings. mine had a knob and cable at the top strut plate for adjustment. Im not crazy about this setup. do you have recepts when you purchased. and photos of what you have. thanks
2012 zl1 stock 7000 miles
2010 TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems. Edit Signature |
12-25-2018, 05:04 PM | #3 |
Sent a pm. To be clear, these will not work with 17” wheels
12-26-2018, 05:47 PM | #4 |
where do adjust the rebound? cant see it in the photo
