05-05-2019, 08:58 AM | #1 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
Knocking from the back of the car
Certainly someone has already registered it.
The car stands on place, the engine running and suddenly somewhere around the axle .... knock, knock, knock, knock. And then quiet again. Car rides normally - all right. What is this..? |
05-05-2019, 09:06 AM | #2 |
Drives: 2010 inferno orange 2SS 6spd Join Date: Apr 2012
happened to me too. Sounds like someone is knocking to get my attention.. I look back and no one is there. Fuel pump???
roto fab cai
bbk full length headers High flow cats 411rwhp/411trq engine pulled/ oil pump fail 525 crate engine installed 391 gear installed 226/236 110 cam tuned by full throttle speed 443@6000rpm /420trq@4900rpm |
05-05-2019, 09:27 AM | #3 |
05-05-2019, 09:37 AM | #4 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
missing any kids or wife.maybe they are trying to get out...
05-05-2019, 09:44 AM | #5 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
I hear this from time to time. Haven’t been able to locate the source yet. It happens so fast.
05-05-2019, 09:46 AM | #6 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Problem solved- ex-wife in trunk!
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
05-05-2019, 09:53 AM | #7 |
Drives: 2015 Z/22 Join Date: Aug 2015
Do you only hear the knocks after a cold start, and a few minutes after running/driving? I hear this too; I'm on my second Camaro and the exact same thing happens, so I guess it's supposed to happen. The knocking happens after a certain amount of time every time, whether the car is idling or moving. I also figured it was the fuel pump.
05-05-2019, 11:17 AM | #8 | |
A few minutes after turning the key. You mean a fuel pump? Fuel pump sounds buzzing. This sound is knocking... |
05-05-2019, 01:42 PM | #9 |
This is supposed to happen. It is a distinctive tap-tap-tap-tap-tap
It freaked me out the first time I heard it. It sounds like someone is knocking on the trunk. It has to do with the evap system.
05-05-2019, 02:02 PM | #10 |
Yes happens when just start up start to move just a little and knock knock knock.. I turn my head back to look every time... Scares me
roto fab cai
05-05-2019, 02:15 PM | #11 |
05-05-2019, 02:56 PM | #12 |
Drives: 2013 2SS/RS Join Date: Nov 2015
Never heard this before........I'll take a listen the next time I cold start it.
05-05-2019, 03:11 PM | #13 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
That dead hooker isn't as dead as you though.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
05-05-2019, 05:34 PM | #14 |
Per forum member Russell James:
"PCM clicks it, seals the tank, then applies engine vacuum, click it to seal off that vacuum, and a few seconds later checks the pressure sensor to see if it is maintaining a vacuum. Then clicks and releases the vacuum. Leave your gas cap loose, and if it fails two of those tests in a row, it'll turn on your check engine light."
