08-28-2019, 11:01 AM | #1 |
Lf info on traction and suspension
So I am getting ready to get a tvs2300 heartbeat and 3200 stall converter installed.
I've been told the 3200 stall is a little high because the heartbeat puts down so much low end torque and that I may just blow off the tires. I currently have 315 on 20x11s nt555g2's. This is my daily so is there any recommendations on tires and or wheels if I do run into problems with traction on the street? (Looking for specific sizes) Plus any other knowledge on what other mods may be helpful(suspension set up is all currently stock). |
08-28-2019, 11:36 AM | #2 |
Drives: All things Turbocharged Join Date: Dec 2010
Really depends on what other mods you are going to do other than just a bolt on TVS2300. Cause just the supercharger is only going to gain about 120hp. That's not enough to be concerned about. If it's not too late to change your mind on the stall, I would say get a 2800. A 3200 is usually better for centrifugal or turbos. Or maybe even keep stock stall and put 3.91 rear in it if you are going to be only +120hp. It's not a lot of power for the weight of these cars. And hitting it 'hard' right off the line is not that important on the street.
08-28-2019, 11:55 AM | #3 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
You're asking a good question. Adding a little more power means a chance of having to add a little more beef to the suspension. One quick and relatively cheap insurance is to swap out your rear toe rods and trailing arms (e.g. BMR stuff). They'll really help reduce wheel hop, which is a killer to axles. Plus, it'll help planting the rear just a little.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
08-28-2019, 12:39 PM | #4 | |
But ya I think I'll go with the bmr stuff to help out.. but you think with this stall and just the bolt on tvs2300 it shouldn't be to bad? |
08-28-2019, 12:46 PM | #5 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I probably wouldn't mess with the converter if I was an auto. I have over 400WTQ at 2250 RPM. If you aren't going for max effort racing, the stock stall will be much happier for daily driving. I also get full traction on a hot day with my Hankook ventus rs3 305's
08-28-2019, 01:08 PM | #6 | |
08-30-2019, 08:58 PM | #7 |
Drives: 2010 2SS/RS Join Date: May 2010
Listen to the big dogs on this site. Go small on stall. 3200 is too much with a blower ....period.
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! Last edited by ZX1truth; 08-30-2019 at 09:10 PM. Reason: correction |
