12-26-2015, 02:51 AM | #1 |
Drives: 2013 camaro ZL1 Join Date: Sep 2015
Aiming for 600whp on a Automatic
Will it be possible to reach 600whp on a automatic with the following mods
Rotofab Intake VMAX TB 10% harmonic balancer 2.55 upper pulley 85lb injectors AFCO HX ? |
12-26-2015, 07:26 AM | #2 |
Drives: '21 ZLE A10 Join Date: May 2012
No, a 10% lower isn't enough. Up the lower diameter to a 9.55" and swap the cam and that will make 600rwhp on 93 octane.
12-26-2015, 08:44 AM | #3 |
Drives: 2014 Camaro ZL1 Join Date: Dec 2014
I got 560rwhp on a mainline dyno (which reads low numbers compared to other dynos) with the following mods-
Intake 2.55 pulley straight pipes 63Pd/hr injectors Afco Hx 160 Thermostat Tune So with ur 10% lower pulley , you will def be around 600ish, wanna add headers then it will get better ...
Lingenfelter 630Hp Package , Afco Heatexchanger , Moroso Catchcan , D3 Tank , Siemens 63Pds/hr Injectors , Custom tune.
12-26-2015, 10:09 AM | #4 | |
Hide! My wife's coming!
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2011
Stainless Power Headers w/ stock NPP Magnaflow Resolnated X-Pipe (I live in an APT and without it, it was sooo loud) Roto-Fab CAI w/ Big Gulp & Washer BTL Relo ADM 10 Bolt SC Pulley Hub ADM 2.55 8 RIB 10 Bolt Pulley Lingenfelter 9.17 Lower Pulley ADM SC Isolator Coupling 8 RIB POLY V Belt for 10% OD CNC Ported LSA Cylinder heads LS9 CAM ADM 3 BOLT CAM Conversion Kit ADM Heat Exchanger w/Reservoir ADM Ported Inlet ADM Ported 90MM TB 85lb Fuel Injectors NGK Iridium Spark Plugs 160 Degree Thermostat ADM Custom Dyno Tune
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
12-26-2015, 10:09 AM | #5 |
Here is a thread with videos after I did the work at ADM
http://www.camaro5.com/forums/showthread.php?t=372952
