#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Suspension | Brakes | Chassis
AWE Tuning
Old 08-24-2016, 07:01 PM   #1
HurstPerformance
HurstPerformance's Avatar
Drives: 2013 Camaro SS and 2016 Camaro SS
Hurst Spring Kits Are Coming Soon for 2016-2017 Camaros
We just finished installing a set of Hurst springs on our 6th gen. Thoughts on the stance?
HurstPerformance is offline   Reply With Quote
Old 08-24-2016, 11:38 PM   #2
rorymick
rorymick's Avatar
Drives: 2016 Camaro RS 1LT 2.0L Turbo
Looks good! Hopefully you guys will post up spring rates and ride height etc!
'16 1LT 2.0T RS - Catless DP, Intake, Tune/ Eibach springs FE3 shocks/ BMR front bar FE4 rear bar/ Xpel'd front end, CP Reload sealed/ Radenso Pro M.
rorymick is offline   Reply With Quote
Old 08-25-2016, 12:00 AM   #3
G Fo12ce
G Fo12ce's Avatar
Drives: '16 2SS
Looks good, about an inch? Do you plan to make them for MRC?
My Intro Post | My Order | My Ordering Guide
TJCR2Q | 2SS Red Hot|Adrenaline Red|MX0 A8|56R Wheels|5ZU Blade Spoiler|NPP Exhaust|F55 MRC|IO6 Nav
• 4/06/16 1100 Ordered (waiting for 5ZU acceptance)
• 4/19/16 2000 Accepted with 5ZU
• 4/23/16 3000 TPW:5/16/16
• 5/06/16 3100
• 5/13/16 3400 Broadcast Sheet
• 5/24/16 3800 Vehicle Produced
• 5/25/16 4B00 Bayed
• 5/27/16 4300 Intermediate Delivery
• 7/9/16 Delivered!
G Fo12ce is offline   Reply With Quote
Old 08-25-2016, 10:59 AM   #4
HurstPerformance
Thanks! The rates for the springs in this pic are: 150 lb/in. front and 420/550 lb/in. rear. Once we go into production we will absolutely provide final spring rate and ride height info.
Good eye. We are looking for a 1.0" drop front and rear. We will keep you all updated on whether or not we will release springs for cars with magnetic ride control. Thanks for asking.
Old 08-25-2016, 11:18 AM   #5
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Are you sure it's not the other way around? That seems very low for front spring rate and very high for rear spring rate.
vtirocz is offline   Reply With Quote
Old 08-25-2016, 04:04 PM   #6
crankaholic
crankaholic's Avatar
Drives: 2016 Camaro 2SS
Looks great!
What are the tire sizes on that car?
crankaholic is offline   Reply With Quote
Old 08-30-2016, 06:21 PM   #7
HurstPerformance
Yes. These are the correct rates for the springs pictured.
Originally Posted by crankaholic View Post
Looks great!
Thanks! Tires are 245/45/20 front and 275/40/20 rear.
Old 08-31-2016, 12:44 AM   #8
JaxChris
Drives: '16 2SS GD1 MX0 NPP F55 IO6
550 lbs/in is way too stiff for cruising or commuting. I'm guessing that will be your drag spring?
JaxChris is offline   Reply With Quote
Old 09-27-2016, 03:29 PM   #9
HurstPerformance
The ride is actually really nice. Our springs are roughly 8-10% stiffer than factory springs.
Old 09-30-2016, 09:00 PM   #10
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Stance nice, wheel suck. Just saying
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
laynlo15 is offline   Reply With Quote
Old 10-21-2016, 12:36 PM   #11
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
With the motion ratio in the rear a 550 lbs/in spring rate works out to ~150 lbs/in wheel rate. It is not very stiff.
rotis is offline   Reply With Quote
Old 08-09-2017, 04:10 PM   #12
HurstPerformance
Whether you're looking to complete your 'Elite Series' build, or just want better handling from your modern muscle car, join Steve as he explains what makes these springs a great upgrade for your ride.
2017, hurst, lowered, springs, suspension
