Old 08-19-2012, 10:42 AM   #1
cid067
cid067's Avatar
Drives: Black 1SS/RS LS3 M6 "The Toy"
#7 cylinder valve spring
Does anyone have a trick to get the #7 cylinder back valve spring off cant get the valve spring compressor on it to compress the spring.
2010 1SS/RS Diablo Sport Trinity JRE Tune OBX headers with Cat delete Borla Cat back Volant PowerCore CAI BMR adjustable trialing arms 4.11 Gears JRE cam package.
cid067 is offline   Reply With Quote
Old 08-19-2012, 12:58 PM   #2
toml_pa
ʇuɐıʌǝp lɐıɔos
Drives: 2011 2SS/RS LS3/M6
This what I used to install dual springs with no problem. Got it here.
toml_pa is offline   Reply With Quote
Old 08-19-2012, 01:15 PM   #3
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Crane Cams compressor. Wasnt even a challenge.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 08-19-2012, 01:35 PM   #4
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
You must be using a screw down hand compressor, those are junk. Use the crane tool, or the ebay tool.
http://www.ebay.com/itm/LS1-LS2-LS3-...-/190673501726
pouncer72 is offline   Reply With Quote
Old 08-19-2012, 04:27 PM   #5
cid067
cid067's Avatar
Yes the screw down worked fine for all the others just cant get it in on the spring in the back just not enough room in there. Got the spring off with a fabricated tool like the ebay one about to put the new spring on hopefully the tool I made will work as easy as getting it off.
Old 08-19-2012, 05:23 PM   #6
cid067
cid067's Avatar
Thank Michael most thank god I have to thank my 15yr old son who finally go the spring on was getting frustrated had him give it a shot while I took the balance puller back came home he had it on that is outstanding.
