04-10-2017, 12:02 PM | #1 |
Drives: 13' 1LE Join Date: Apr 2012
#1/4 mile results UPDATE# Installing modded manifold and ported TB
Very excited to install rod mod&cleaned/ported LS3 manifold with ported TB!! This with my Vararam DRX!! YAY!!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. Last edited by WHAMMO; 05-21-2017 at 02:46 PM. |
04-10-2017, 12:57 PM | #2 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
Did you happen to have a before dyno and are doing an after? I'm curious to see what the rod mod intake actually does.
04-10-2017, 01:23 PM | #3 |
OHHHHHH
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
04-10-2017, 07:13 PM | #4 | |
Yahhhh!!! 😆😆😆 Tou know the guy
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
04-10-2017, 07:42 PM | #5 |
04-10-2017, 09:07 PM | #6 |
Drives: ‘13 1LE Join Date: Jul 2013
Good stuff!!
Did you perform the rod mod, or did you have Crawford do it? |
04-10-2017, 09:14 PM | #7 |
These are HioSSilver ported pieces
04-10-2017, 09:41 PM | #8 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Looks good man, can't wait to see the difference it makes!
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
04-10-2017, 11:58 PM | #9 |
04-11-2017, 12:55 AM | #10 | |
Yep!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. Last edited by WHAMMO; 04-11-2017 at 01:10 AM. |
04-11-2017, 01:05 AM | #11 |
Just to give some feedback, car is not having any idle problem or anything. I did notice a difference when I press the cluth, rpm seems to go up a bit but maybe Im rusty to drive it on 1st day out.
Vararam CAI went ok but its a little bit of a PITA to remove washer tank. As for the SOTP feel, I aint sure of anything. Need more seat time. Car is 535hp so a 15hp wont be like night n day. I think it needs a retune to maximize gains. "Ram air" setup will shine in 3rd and 4th, which I couldnt test at WOT.
13' 1LE
04-11-2017, 09:08 AM | #12 |
I'm confused, what is the actual HP yours makes?
04-11-2017, 06:16 PM | #13 |
It made 440rwhp on a Mustang dyno OR 535ish fwhp(wallace BS hp calculator based on track/DA/weight). It all adds up with Texas Speed R&D engine dyno and my ET time.
Same day same dyno a 640hp Viper made 530rwhp FWIW. Viper made this number in "dynojet settings" and made 460rwhp in mustang settings LOL
13' 1LE
04-11-2017, 06:32 PM | #14 |
How's it driving Johnny?
