08-20-2015, 06:25 AM | #1 |
Drives: 2014 RedRock 1LE Join Date: Jul 2012
Cam install and oil pressure question.
Hey guys I'm doing a cam , heads , headers and cai install . When I started up the car what should the oil pressure in " bars " read ? I have a. 20141le and it reads in bars
498RWHP 439RWTQ Instagram: jm_103
08-20-2015, 06:47 AM | #2 |
14.5 pounds per square inch is a bar.
08-20-2015, 07:47 AM | #3 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
When cold the oil pressure at idle on mine is above 30 psi, so probably something above 2 bar is normal.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
