Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 09-05-2018, 10:34 PM   #1
K3V7N
Drives: '15 SS 1LE
Track Prep
Taking my new-to-me '15 SS 1LE out on Watkins Glen next month. Any tips for prep? I have fairly new Conti Extreme Contact summer tires.
I've done many track days out in California; on cars such as a Cayman GTS, 997 GT3, C7 Z06, and new C63.
K3V7N is offline   Reply With Quote
Old 09-06-2018, 07:16 AM   #2
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Are you doing a HPDE? Fresh pads and brake fluid are important. WGI has a couple of HEAVY braking zones. Tires should be fine - I'm not sure at what temperature those become a liability but you have the nice cool fall weather working in your favor there. Fresh fluids in the motor/trans/rear are always a good idea. If you're not sure of the history it might be a good time to take care of those things, depending on miles.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 09-07-2018, 07:27 AM   #3
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Agreed on pads and fluid. Err on the side of conservatism here, given that your description of previous experience tells me you won't be running at lead-follow novice pace.
Give some attention to alignment settings as well. Just because it's a 1LE doesn't mean that it's alignment is truly ready for track use. JusticePete (http://www.jpssonline.com/) is a good source for the details - he wrote "the book" on 5th gens for performance suspension & handling, and "the book" should be viewable at that site. If you talk to him, tell him I sent you.
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously)
Norm Peterson is offline   Reply With Quote
Old 09-07-2018, 05:20 PM   #4
K3V7N
Drives: '15 SS 1LE
Thanks! I definitely don't do lead/follow and usually go in the intermediate groups.
Old 09-08-2018, 07:39 AM   #5
MonroeZ28
Drives: 15 z28 white
I’m not sure if you’ve ever been to the Glen before from your post? If not, be prepared to experience the best road coarse in the east in my, and many other people’s opinions. (I have to admit that I’ve never been to VIR though)
MonroeZ28 is offline   Reply With Quote
Old 09-09-2018, 09:15 PM   #6
K3V7N
Drives: '15 SS 1LE
Never driven it, but was at a race last weekend as a spectator. It looks great - much different than the tracks I'm used to in southern California.
Old 09-09-2018, 09:17 PM   #7
K3V7N
Drives: '15 SS 1LE
P.S. This will give you a taste of desert driving (one of my old favorite tracks in my Z06): https://youtu.be/UxcBQTZRDpg
Old 09-09-2018, 09:24 PM   #8
td195f
td195f's Avatar
Drives: 2015 Z/28 #786
What group are you doing your event with?
Good, fresh Brake Fluid (I use Motul RBF600) and a spare set of brake pads if you are running stock pads. Track pads would be better. Tires should be fine. Do some research and see what Conti recommends for cold and hot pressures. DO NOT go by what the owners manual says. Chevy recommended some very high starting pressures for my Pirelli's. Pirelli recommended a hot pressure of 32 to 33 psi which is a cold starting pressure of about 26 to 26.5 psi.
Lots of speed and not a lot of run off room in some places, especially up thru the esses.
Make sure your helmet is an SA2010 or 2015. Also some groups are requiring the face shield be removed or down in any car with air bags.
2015 Z/28 #786 - Black
2004 Silverado 3500 Dually - D'Max - Suncoast - Banks - Edge - Custom Tune by D'Max Tuner / Spitzer '32 Bantam Altered Drag Car - Blown Alcohol 380 CI Small Block Chevy
td195f is offline   Reply With Quote
