Old 05-10-2017, 03:58 AM   #1
Quicksilverman
Drives: 2012 Chevrolet Camaro
Arrow Best motor oil to use in a 10-15 Camaro?
What is the best motor oil to use in a 10-15 Camaro? We have only used Valvoline 5W30 Synpower synthetic motor oil "Dexos approved" in our 2012 Camaro 3.6L V6 with a K&N oil filter since brand new with 7 miles on it and never had a one problem that was oil related. Why does GM highly recommend Mobil 1 5W30 synthetic motor oil "Dexos approved of course"? I never ran Mobil 1 synthetic motor oil in any of the vehicles I ever owned I just wanted to know. Do you have to use Mobil 1 synthetic motor oil to maintain your engine warranty?
Quicksilverman is offline   Reply With Quote
Old 05-10-2017, 05:33 AM   #2
myold88
myold88's Avatar
^^^^ No you don't . But I believe it's more important to change the oil often, rather than
what brand of oil you use. I changed my oil yesterday for the 12th time in 8 years and
47,000 miles. I never use the computer's "% remaining" indicated by the Camaro's computer.
Old 05-10-2017, 08:49 AM   #3
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Because Mobil 1 pays them to say that.
No you don't NEED to use Mobil 1 for the warranty, but you need to use Dexos approved oil, keep receipts and records, and be able to prove that you have used a Dexos spec'd oil in the event that you do need to warranty the drivetrain.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 05-10-2017, 09:22 AM   #4
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
I like Mobil1 but love Amsoil
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 05-10-2017, 10:26 AM   #5
DonM
Camaro #4
DonM's Avatar
Drives: 2017-Hyper Blue Metallic-2LTmanual
Don M
Supercharged LGX + 6 speed manual = FUN!!
DonM is offline   Reply With Quote
Old 05-10-2017, 02:02 PM   #6
SharpOldNo7
SharpOldNo7's Avatar
Drives: 2015 2LT RS Convertible
another oil thread.
Personally I use Mobil1 in pretty much everything that I change the oils in myself except for my 93 F150 which has always been on Dino oil. I've never personally changed the oil in my 2011 F150 as the dealer will change it with SynBlend for $30.
SharpOldNo7 is offline   Reply With Quote
Old 05-10-2017, 03:17 PM   #7
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
GM use Mobil1 based on in house test data that shows it to be the best choice for the lowest lubrication / friction related warranty costs. If there were something better, they would use it.
Old 05-10-2017, 03:44 PM   #8
ChibiBlackSheep
Is that true? I always thought there was money exchanging hands and that they just slap a name on it. I assumed they did all of their testing based on Dexos minimum specs.
Why do they have a GM Dexos oil that you can buy if they use Mobil1 in-house?
(Not trying to argue the point, just genuinely curious)
Old 05-10-2017, 04:25 PM   #9
JusticePete
I know a number of GM engineers that race or have raced on their own dime. They all use Mobil1 based on what they have seen and know from the inside. As I understand it, Mobil1 is the 'premium' oil for high performance and Dexos a minimum standard.
Old 05-10-2017, 05:48 PM   #10
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
Besides my Camaro I also own a 96 Impala SS that has been significantly but professionally modified, in this vehicle I only use Royal Purple 10-30 full synthetic with K&N filters. The Camaro I use Royal Purple 5-30 full synthetic with K&N filters also. I usually purchase my Royal Purple from Summit Racing who has the best price, majority of the time, and free shipping.
Deputy347k9 is offline   Reply With Quote
Old 05-10-2017, 07:34 PM   #11
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
Mobil1 since day one. 22k on mine and 4 oil changes under my belt. Every 5k regardless of what the indicator says. Check my oil often to make sure level hasn't dropped since I have a catch can that collects a significant amount of oil between changes.
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 05-11-2017, 07:11 AM   #12
13coupe
13coupe's Avatar
Drives: Crystal Red 1SS Coupe 6spd manual
Smokey Yunick used to say MOB so not to overtly endorse but we know what he meant.
13coupe is offline   Reply With Quote
Old 05-11-2017, 08:11 AM   #13
Avenging Orange
Avenging Orange's Avatar
Best choice is...pick one.....use it....change it religiously and enjoy.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 05-13-2017, 11:16 PM   #14
tlavoie87
Built Not Bought
tlavoie87's Avatar
Drives: 2010 Twin Turbo LFX
Rotella T6
2010 Twin Turbo LFX
In Memory of my DAD Gone but never Forgotten 2014
"Built Not Bought!'
Sponsors:
OverKill Motorsports
tlavoie87 is offline   Reply With Quote
