Old 03-06-2011, 02:35 PM   #1
MA2010SS
Drives: 2010 Camaro SS
New 4.11's installed Thanks Jannetty
First off I would like to thank Ted and his group for doing a great job on the gear swap . Took about 2 hours of remove and replace the unit on my part, about 45min out and a little over an hour back in. Programmed the pcm for the new gears so the speedo was on track. I have to say that rowing through the gears is so much better with the 4.11 and GM SHOULD make this an option, but it is what it is. Car feels so much stronger and stays in the power in every gear. With that being said I'm going to have to wait a while until the unit if fully broken in at around 500 miles or so, change the fluid and off to the track to hopefully see the difference (driver needs practice.)
MA2010SS is offline   Reply With Quote
Old 03-06-2011, 05:46 PM   #2
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
What did you use to program the ECM for the speedometer update ?.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
flht99b is offline   Reply With Quote
Old 03-07-2011, 12:12 AM   #3
steeleshark2
steeleshark2's Avatar
How much more noise do you hear with these gears?
Old 03-07-2011, 06:00 AM   #4
JKLNHYD
Defending the Nation...
JKLNHYD's Avatar
Drives: '16 Summit White 2SS, A8, Sunroof
A properly installed set of gears should not make enough noise to hear in the cabin..
'16 2SS, A8, Sunroof, non-NPP
"SURSUM AB ORDINE"
JKLNHYD is offline   Reply With Quote
Old 03-07-2011, 08:03 AM   #5
MA2010SS
Ed M.
I used HP Tuners software to calibrate the speedo. There is very little whine and I only drove it about 5 miles after install, after the 500 mile break in there should be no whine whatsoever. Very happy with Jannetty's set up
Old 03-08-2011, 10:20 PM   #6
55Designs
Drives: 2010
150 miles to go on the break in which seems forever driving in the NYC Metro area, its like a war zone with rutted roads here. I plan to do a diff flush and refill this saturday.
55Designs is offline   Reply With Quote
Old 03-08-2011, 10:23 PM   #7
55Designs
Drives: 2010
Add solid diff bushings and other bushings from a race car then remove the shield and add a single piece driveshaft and the noise is insane. Unbearable on the parkway for more than 10 minutes.
Gonna plan around taming this down so customers dont freak out when they drive our test car. Feels incredible otherwise. I honestly think the swap on the diff bushings to normal poly will help alot.
Old 03-08-2011, 10:25 PM   #8
L99 or LS3?
Old 03-09-2011, 04:28 AM   #9
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
Lol, like 454lsx crate motors........ sorry, couldn't help it . I know they do great work but alchemy is a little much
Irnwkrkev is offline   Reply With Quote
Old 03-10-2011, 02:33 PM   #10
GeorgeM
Drives: 2016 2SS, Yellowjacket, A8
Did the digital speedometer get corrected as well?
GeorgeM
GeorgeM is offline   Reply With Quote
Old 03-10-2011, 08:25 PM   #11
S-eatin-grin
S-eatin-grin's Avatar
Drives: 2013 2SS/RS AGM
Cool...I'm in line for this next month, ording from JRE but doing the diff swap and installed at a different shop. Are you taking the car back after 500 miles or changing the diff fluid yourself?
S-eatin-grin is offline   Reply With Quote
Old 03-11-2011, 08:05 AM   #12
MA2010SS
GeorgeM
Everything was right on after the calibration, digital would read 50 and the dial also read 50...I have about another 400miles to put on in order to break it in right and change out the fluid
Old 03-11-2011, 12:15 PM   #13
FiveO
FiveO's Avatar
Drives: 2011 Camaro SS 6speed Manual
I'm on the fence with either 373 or 411's so hopfully you all can let me know if the noise is unbearable or not.
FiveO is offline   Reply With Quote
Old 03-11-2011, 12:30 PM   #14
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Correction. Boosted "454lsx crate motors......". :-)
Originally Posted by bigcamaro View Post
i'm not allowed to talk about the ridiculously thin cylinder walls sonic testing found.
i will not talk about it
Hahahahaha....... to both posts. No matter how good you are, never stop learning and usually from big mistakes. LOL
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
calbert1999 is offline   Reply With Quote
Camaro Dove Tail Spoilers Compilation daphatgrant Cosmetics and Lighting Modification Discussions 470 10-28-2020 02:35 PM
Racing Brake 2 pc Rotors Installed mtcwby Suspension / Brakes / Chassis 36 11-13-2010 05:07 PM
JANNETTY RACING & VORTECH YSI MAKE 742.5 RWHP JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 10-21-2010 03:40 PM
MY NEW CAMARO-NEW MODS BY JANNETTY RACING prostreetbuyer Vendor and Seller review / feedback / experiences 8 04-20-2010 10:04 PM
Another Dealer Installed Stripe Problem 69er Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 07-13-2009 03:32 PM
